Where's the best place to stick the trolley jack so i can get my axle stands under the front please men
and dont say "up yer arse"
| Author | Subject: Jacking Up |
mellowr1
Senior User Location: Maidstone Registered: 12 Jun 2012 Posts: 995 Status: Offline |
And i dont mean usin any drug paraphernalia Where's the best place to stick the trolley jack so i can get my axle stands under the front please men and dont say "up yer arse" |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
Are you asking where is it safe to jack off? ![]() ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
mellowr1
jack on i think |
I would say the chassis rail if your car is not lowered.________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
on the jacking point, or the middle of the subframe, never the chassis rail, they aren't strong enough.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Miss Ladybell
Senior User Location: behind you Registered: 20 Feb 2012 Posts: 635 Status: Offline |
cjm_harris wrote: Are you asking where is it safe to jack off? ![]() ![]() Ill help.... ![]() |
welshpug! wrote: on the jacking point, or the middle of the subframe, never the chassis rail, they aren't strong enough. I was unsure about the chassis rail. I've never tried as my car is lowered so cant get to it with trolley jack. ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
Miss Ladybell wrote: cjm_harris wrote: Are you asking where is it safe to jack off? ![]() ![]() Ill help.... ![]() ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
30ASTOR6
Regular Location: shrewsbury Registered: 19 Mar 2012 Posts: 317 Status: Offline |
lad over the road once jacked his car up under fuel tank the f**king dim wit! His uncle is a s**t mechanic and is always repairing his cock ups for example his old astra had no antifreeze in it so it froze the tit boild the kettle and poured it over engine and knocked out all the core plugs then tried to start it and snapped cam belt because water pump was froze ![]() ________________________________________ TEAM ASTOR GTi 6SNAP-ON SUBARU SOON NOT TO BE TEAM DIABLO MEREDIAN (for sale) |
^lolBy the way them chassis rails bend in if you do it there ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
mellowr1
so.....................where is the jacking point for a trolley jack and where would i place the axle stands so i dont end up with crushed underside |
mellowr1
Miss Ladybell wrote: Ill help.... ![]() ![]() send me a pic n il think about it |
I usually jack up under the subframe using a block of wood to spread the load and prevent scratching the paint. Then when the front end is up put the axle stands under the jacking points on the sills, using rubber pads to prevent scratching the jacking points.Alternately if i just want a wheel off i jack up on the jacking point on the sill. ________________________________________ Goldie the track car. |
Jack the car up on the sill and place the stand under the subframe ? Mine seem to fit nicely between the bolts on the sub frame |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Yep chassis rails are as soft as butter. My car along with a lot of others it seems has been jacked up in the past on the floor or the sturdy-looking transverse "beam" things (that are actually made of metal thin enough to cut with tin-snips!!) behind the front wheels. Consequently there is rust there that I need to get fixed and the floor bent back into place. Rear of subframe, rear axle tube or sill jacking points only! ________________________________________ Cherry Rallye SOLD |
Yeah they look sturdy but I guess not ![]() Some numpty at some point owning my car jacked it up from the drivers side footwell. All of the sill is damaged as well. so just got loads worse since ive owned it, looks shocking. My mate says because its french and its made of cheese ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
nadium
Regular Location: denmark Registered: 18 Jan 2007 Posts: 241 Status: Offline |
miss ladybell can you help me to ?need a fluid change |
stan_306gti6
nadium wrote: miss ladybell can you help me to ? need a fluid change ![]() ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
russbez
lolyep last owners of my car made a nice mess of my chassie rails kind of thing i never knew to look at when buying a second hand car, then again it was 5/6 yrs ago and i knew very little about the grief this car would cause me ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
