Author Subject: Has anyone tried replacing the brake load sensing valve?
ben8s8
Its the component on a spring by the side of the rear drivers side wheel. Any tips on getting this off?
Thanks.
Posted 29th Jun 2012 at 17:57
smithers
Did one on a saxo before. Lots of WD40 and a wire brush round the brake unions. Be prepared to make new lines up if need be and use a proper brake union spanner. Other than that tis quite simple. Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 30th Jun 2012 at 09:13
midlife
You may not need to replace it.....
Cool
Team 330™Cool
Team "no front end or engine"
Posted 30th Jun 2012 at 11:14
darzmat
Cool
why cant diagrams in hains manuals be that simple to understand LOL
Posted 30th Jun 2012 at 11:15
ben8s8
Unfortunately the actual metal shaft within the spring on mine has completely snapped in half! Thanks for the diagram though.
Also, just so others on the forum are warned, I called Peugeot and they no longer supply this part anymore!
Posted 30th Jun 2012 at 11:38
you can get them from motor factors Unsure
Posted 30th Jun 2012 at 11:43
jord294
Having spoken to my parts guy in Peugeot. He says the press regulator is still available, and comes with rod and spring.
But as rikky says, try a motor factors, as I would imagine it would be cheaper Thumbs up
Posted 30th Jun 2012 at 11:50
smegal
You'll struggle to get a new rod and spring without buying the regulator.
A scrappy may have one. At the very least they are fitted to 306s and xsaras.
Ex SC-6
Now in a Megane R26
Posted 1st Jul 2012 at 16:32
