Author Subject: Rounded wheel bolt
davewagon
Well my locking wheel nut is not round and completely stripped and the wheel bolt is seemingly made of chocolate.
(Part of the reason why I cant' go to pugfest!)
Soooo how do i get it off?
Do i smack on a tight fitting nut and then try to crack it off?
If so, what size would anyone recommend? 18mm?
(am I better off buying a single socket from halfrauds to do the job(not have to worry about damaging my own socket then)
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 1st Jul 2012 at 11:39
chris with a pug
Yeah try that, what kind of bolt is it?
You could try your local back street motor factors, some sell the proper tool for it, about a tenner I think.
Posted 1st Jul 2012 at 11:49
davewagon
Its just the standard Peugeot locking bolt (i.e. crap) for cyclones.
Will give it a go then
Posted 1st Jul 2012 at 11:52
midlife
I had this problem, drill a 5mm hole through the head down into the threaded part of the bolt, follow this down carefully with a 12mm drill, when you get to the correct depth the head should drop off.
Good luckThumbs up
Cool
Team 330™Cool
Team "no front end or engine"
Posted 1st Jul 2012 at 12:01
davewagon
Good luckThumbs up
Cool
Bloody hell, that sounds a bit involved for me (in my current hungover state)
Will try busting it off first, then attempt this
Cheers, Dave
Posted 1st Jul 2012 at 12:46
smegal
Just twat a 12 point socket on the round part then crack it off
Ex SC-6
Now in a Megane R26
Posted 1st Jul 2012 at 16:02
davewagon
Yeah I just been trying this
I can only seem to get an 18mm 12 point socket on, but it is slipping when i try to undo it.
Cant get a 17mm on, so what now?
I have socket to remove rounded bolts, but need an impact wrench/gun really
Not sure I want to try drilling down it
Posted 1st Jul 2012 at 16:36
T400 PUG Banned!
i did some by drilling a 6 or 8 mm hole down a cm or so smacking a slightly bigger torx socket into it and then undo as usual.
Posted 1st Jul 2012 at 16:39
fatlapit
Irwin bolt grips mate thats wat u need
Posted 1st Jul 2012 at 17:14
tvrfan007
Twat an 11/16" 12 sider on if you can't get a 17 on. Yes
I got some over-torqued lockers off like that, the gay round ones.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 1st Jul 2012 at 19:00
barnettjd77
They are the thing for a job like this!Thumbs up
had to do 3 myself.LOL
A red rallye in progress!
Posted 1st Jul 2012 at 19:44
smegal
Ex SC-6
Now in a Megane R26
Posted 1st Jul 2012 at 22:42
calibra306
I used a solid chisle and punch on mine!
used the chisle which with a few wacks loosened them leaving a big chunk in the nut and then used the punch in the holes to wack is round until it was loose enough to remove with pliers etc.
All but one was a real pain in the ass due to me making sure they were just a little tight when the wheels were last off as i could see the pins starting to go!
V6 Power!
Faster I can go the better!
Posted 1st Jul 2012 at 22:51
daver6
In the past, I've had to weld a nut onto the bolt and remove it that way.
The locking nuts must be made of cheese
Wishbone Polybushes available
Posted 1st Jul 2012 at 22:53
Use an Irwin bolt remover as suggested. Is actually quicker than if you had the key.
One of those things you'd rarely use, but when you need something like it they are worth their weight in gold. Anyone that doesn't have a set, buy them for the back of the cupboard. £20 well spent.
  • Posted 1st Jul 2012 at 23:05
    30ASTOR6
    this is true being a mechanic i brought snap on ones they are deffo best tool i brought get out of s**t loads sometimes the nut doesn't even look like a nut anymore but as if by magic they come undone!
    When i brought my gti6 of andy i couldn't find locking wheel nut socket so whacked them out with extractor socket took 2 mins then when i was cleaning out boot found it tucked inside rear of boot! Doh
    TEAM ASTOR GTi 6
    SNAP-ON SUBARU
    SOON NOT TO BE TEAM DIABLO MEREDIAN (for sale)
    Posted 2nd Jul 2012 at 07:14
    davewagon
    Do you need an air gun for these?
    Or breaker bar do?
    Posted 2nd Jul 2012 at 14:43
    just a breaker bar.
    Posted 2nd Jul 2012 at 14:48
    They do one set in a box, and then I think it's called an 'Expansion set' with other sizes in. I think from the top of my head it's the expansion set you need for 19mm
  • Posted 2nd Jul 2012 at 14:55
    fatlapit
    breaker bar you hammer them on a bit then breaker bar them off
    Posted 2nd Jul 2012 at 15:04
    jimmyhackers
    id go witht he rounded bolt extractors. Drilling the head off the nut still leaves the thread in the hub. If its a real c**t id suggest getting some heat on the nut to lossen it beforehand
    Posted 2nd Jul 2012 at 15:30
    midlife
    Once the head of the bolt is removed the bit that's left sticking out of the hub will only be finger tight as it's no longer under tensionGeek
    Cool
    Team 330™Cool
    Posted 2nd Jul 2012 at 15:48
    ^^What he said.
    If the sockets aren't going on, just tack weld a nut to it.
    Posted 2nd Jul 2012 at 15:53
    bongo dts
    You can get the rounded bolt removers from Halfrauds as I used a set when my locking key snapped on my old car.
    Should still have them kicking about in the garage somewhere if they can be of any help as I'm not far from M1 J21?
    Posted 2nd Jul 2012 at 18:26
