Just o the off chance ?
| Author | Subject: Forged rods and high comp pistons ? |
Long shot but does anyone have going spare a set of forged rods 88mm with 20 mm gudgepin and some 87mm high comp pistons ? Just o the off chance ? |
say what? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Does anyone have a set of forged rods and high comp pistons ? Rod length of 88mm Piston size 87mm 20mm budget pin ? |
what engine is that for?!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Oh my bad Gti 6 bottom end I already have an 88mm steel crank |
clen666
You may get some blow-by with 67mm pistons.Do you mean 87mm? Standard are 86mm ________________________________________ Team 'unintentional rat look' |
clen666 wrote: You may get some blow-by with 67mm pistons. Do you mean 87mm? Standard are 86mm Yup I mean 87mm I'll do a sneaky edit |
rods will be a lot longer than 88mm too ![]() std is 158. speak to sandy. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Indeed yes they are Not sure what the 88mm is to be honest ? Basically I'm after forged rods to fit in a 6 block on a steel crank with oversized pistons |
clen666
88mm will be the stroke when using the new crank.If you were using standard pistons then you would need rods 1mm shorter (157mm). You will need to work out what is needed looking at piston crown height of the new pistons etc. ________________________________________ Team 'unintentional rat look' |
