Author Subject: Helix Ceramic Clutch and Clutch cable issues
FatBastard
Hello all,
I have a Helix ceramic clutch and constant issues with clutch cables which simply cant stay alive more than several months and are simply get torn apart. Usually its the rubber stuff that gets torn.
The clutch was converted from upside down to regular clutch. it is rather hard and the material of the clutch cables are not strong enough, i guess.
Is there any place which sells stronger cables?
Posted 15th Jul 2012 at 23:29
FatBastard
Another question - can i move to hydraulic clutch - to solve this issue? How complicated is it?
Posted 21st Jul 2012 at 09:34
Im sure i've seen hydraulic conversions done in the past, although i don't know much about it. From memory i think part of the gearbox housing needs to be machined to make space.
Posted 21st Jul 2012 at 13:44
hydraulic can be done yes, I'm also interested in this.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 21st Jul 2012 at 19:10
birk
Me 3 Smile
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 21st Jul 2012 at 19:40
FatBastard
So, which parts does this involve? Smile
Posted 21st Jul 2012 at 20:11
FatBastard
Posted 22nd Jul 2012 at 17:24
Surely it can be done without losing the brake servo, maybe a single pedal box or somthing.
Posted 22nd Jul 2012 at 18:17
FatBastard
Well, here some of the latest pics.
The clutch cable was ok, but the plastic crap was torn apart. So we machined aluminium parts instead of them.
We are going to machine the white plastic part which connects to the hook of the paddle also. Since now its the weakest link.
Posted 28th Jul 2012 at 13:50
birk
Nice.
Let us know how you get on with it.
Is it ok to live and drive with?
07889376885
Dan
Posted 28th Jul 2012 at 14:06
FatBastard
The clutch was always heavy, and i dont feel its harder now. Also, you dont have much room to play with it, you need to rev it a little bit more to shift - but this was always the case with my helix clutch (i have been using helix clutches for 5 years now). Most of my ex-gfs could not drive the car with this clutch - well, not more than around the parking lot (except my ex-Dutch gf, since dutch people cycle a lot and have strong legs). Smile
Posted 29th Jul 2012 at 11:16
birk
Haha.
Only reason I ask, is I will be running a twin plate clutch, and I'm trying to decide if it's worth while keeping the cable.
07889376885
Dan
Posted 29th Jul 2012 at 15:21
staley_306
A friend had this same problem on a 106 only the other week, the cable would brake as the clutch took too much pressure to disengage. Alloy adaptors fixed this.
Posted 30th Jul 2012 at 08:49
FatBastard
Birk, which brand is the intended twin plate?
You can try holding it up with an cable, and if it cant withstand the pressure, move to hydraulic - but its rather expensive.
Posted 30th Jul 2012 at 09:29
birk
Not sure yet, might be ap racing, or a local company might be making me one up.
07889376885
Dan
Posted 30th Jul 2012 at 13:26
would you have to lose the pedal box and brake servo to run hydraulic.
Posted 30th Jul 2012 at 18:42
No, you could have a single hydraulic pedal just for the clutch easy enough.
Posted 31st Jul 2012 at 16:07
yup, it is quite easy, not done it myself but Paul on the 205 forum has done a couple for V6 conversions, in a 205 and a 306 using mainly o.e pug bits.
Posted 31st Jul 2012 at 16:40
birk
You think a 406 hdi gearbox with hydraulic setup would fit the 6, with different gearset inside to make it a nice drive ?
07889376885
Dan
Posted 2nd Aug 2012 at 15:36
