This ^^
"Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6
2000 (X), Moonstone
| Author | Subject: Peogeot 306 GTI 6 Handling - Understeering and how to Kill It |
stan_306gti6
miles wrote: I always say a 30mm rear ARB is fine even for road use, No issue's with them along with solid mounts as along with up-rated front bush's it makes the car turn allot sharper as you don;t have to wait for the rubber to react. This ^^ ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
I sort of wish i got a 30mm arb now :S oh well im sure it will be good enough.________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
stan_306gti6
The 30mm does make quite a difference, it made the rear end of my '6' nice and stiff and coupled with the solid mounts it makes it very predictable which is a quality that I look for in a car. I fitted the 21mm TB's at the same time and the whole setup seems to really work well. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
phillipm wrote: Yeah, should be in tension really - pulling inwards on the strut tops, but not a lot. is that just 306 based info?or all cars with a front strut brace? had mine like that anyway...... not tensioned pushing the struts out...... ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Most cars with struts, unless the strut is outboard of the crossmember/bulkhead connection.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
phillipm wrote: Most cars with struts, unless the strut is outboard of the crossmember/bulkhead connection. Ah right,cheers ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
JimmyC379
Newbie Location: Brisbane Registered: 16 Dec 2011 Posts: 32 Status: Offline |
An update on my handling issues. I have fitted the Koni yellow shocks and 30mm lowered springs to the GTI and handing seems better, however I will see what it is made of this weekend at the track. I think I will need to stiffen the rear torsion bars as it has bottomed out a few times now. I lowed the rear 30mm [same as the front] and the rear looks lower than the front. What height do most people set there rear to front height ratios at and why?Cheers. |
I don't set them lower than 322 between damper bolts on standard bars, equates to about 25mm rear drop, works well with Eibach springs which are reputed to be a 30mm front drop.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #35
JimmyC379 wrote: I lowed the rear 30mm [same as the front] and the rear looks lower than the front. It will because the arches are lower on the rear of the car. You need to measure on a flat hard surface from the chassis rails underneath (if they aren't too crusty). Ideally you want a bit of rake to the front (nose down). ________________________________________ Nothing to see here |
Post #36
welshpug! wrote: I don't set them lower than 322 between damper bolts on standard bars, equates to about 25mm rear drop, works well with Eibach springs which are reputed to be a 30mm front drop. Depends on the dampers used (if they have the correct height platforms) and engine weight - aircon/airbags etc for the front. And of course on the front/rear height/weight distribution. Torsion bars are a pain in the arse ![]() ________________________________________ Nothing to see here |
milkyb
Seasoned Pro Location: West London Registered: 30 Mar 2012 Posts: 1,056 Status: Offline |
Post #37
milkyb wrote: FYI- you have spelt peugeot wrong in title. i always do this also..such a stupidly difficult word to spell |
gota6again
Seasoned Pro Location: Gone Registered: 18 Jan 2009 Posts: 1,595 Status: Offline |
Post #38
milkyb wrote: FYI- you have spelt peugeot wrong in title. i always do this always..such a stupidly difficult word to spell Should have used spell check |
milkyb
Post #39
why you always gotta be a playa hater? |
Post #40
adam b wrote: Torsion bars are a pain in the arse ![]() [/i]Peugeot[/i] torsion bars are a pain in the arse. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
JimmyC379
Post #41
Cheer guys and girls. Once I get some bigger bars I will jack it up 5mm! |
demondriverdan
Post #42
Out of interest, where can we get 30mm ARBs from? ![]() ________________________________________ Rallye Race Car |
JimmyC379
Post #43
I went to the track this weekend and these are my notes:Well handling is defiantly better with the rear konis on the heavyest setting. She is now trypoding majorly - but I am not sure if that is a good thing. With it trypoding I am finding the rear way more unstable. She is still fairly predictable but it does not feel even 80% of what I want it to feel like. Next step will be to upgrade all the bushes to urethane and maybe solid mounts and see how she goes. The linkage also came of the ball joint on a small off so will also need to address this - it was easy to pop back in but had to get towed back to the pits and don't what this to happen again. |
aaron6
Post #44
Stiffer anti roll bar and torsion bars should eliminate the tripoding I'd have though. The solid mounts just stop the passive steer which is a trait I really rather like. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
Post #45
aaron6 wrote: Stiffer anti roll bar and torsion bars should eliminate the tripoding I'd have though. The solid mounts just stop the passive steer which is a trait I really rather like. ![]() My logic would be that it would actually make it tripod more as there would be less 'roll' so will lift the other wheel more easily. ________________________________________ Ryan |
aaron6
Post #46
But with less roll on a flat road could it still clock a leg as it shouldn't be rolling. Well, that was my thinking. I could be wrong though. Often am infact. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Post #47
unless you stiffen up the front corners it will still roll and tripod, though the rear ARB will decrease the amount it does it at by increasing rear slip.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #48
Im going to stick to what i said in the beginning in that you have a standard ish back end with a mega stiff front. You need to stiffen the back to help keep the front on check other wise you will always have understeer.________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
Post #49
If you're still getting terrible understeer try disconnecting the front ARB (without removing the whole thing you can just take out one of the drop links so you can just put that back in if you don't like it). If you've stiffened the front you'll be getting less roll than a standard set up during cornering and so the extra roll stiffness the ARB is providing will make it understeer more. ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
Post #50
It's overly soft springs and an undersized front ARB you need to sort if you want to lessen/eliminate the front end dive & roll that unloads the inside rear and reduces the outside front tyres contact patch all at the same time (not a winning combination) increasing the front track (wider wheels/spacers/longer wishbones etc) will help to reduce roll induced under steer but springs and ARB is where you need to put your money. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
