Author Subject: Wilwoods?
eddy_gti6
Just bought a set of wilwoods with ford fitment braxkets. Will they fit a 306? There to go on my saxo but prety much same fitment as a 306 anyway. Also anyone tell me where i can get discs and what size i can run under 15s?
Posted 19th Jul 2012 at 19:52
chrisd306
depends what brackets you get as to what discs you need, as if you get welly brackets you run standard discs, failing that an you get 205 brackets like what i had you have to use rally design discs id try them for brackets to, but id imagine you will be 200 plus for what nyou need
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 19th Jul 2012 at 19:55
eddy_gti6
No way i could run the 288mm xantia v6 discs thats used with the brembos? What size are the rally design discs?
Posted 19th Jul 2012 at 23:30
mr swampy s16
**BAD SELLER**
Also need different front hoses as willwood use a taper fitting!!!
The rest of your lines will hopefully be with me tomorrow
Posted 19th Jul 2012 at 23:39
eddiebeano
A saxo!
team: Stealth Ninja
Posted 19th Jul 2012 at 23:40
eddy_gti6
How much more for these swampy? Pm me.
Yes eddie a saxo. Bought a rolling shell and cost of parts so far is over £500 and i still dont even have an engine to go in it Laugh my ass off
Posted 19th Jul 2012 at 23:51
mr swampy s16
**BAD SELLER**
£27.50 the pair, direct fit
Same paypal
Posted 20th Jul 2012 at 00:04
eddiebeano
Is it going to be something spectacular?
team: Stealth Ninja
Posted 20th Jul 2012 at 00:06
eddy_gti6
It was going to be a gti6 engined saxo but too much work involved so probs just get some head work done, cams and a map. Them see where i end up after then Wink flocked dash i have just had done is class Love
Posted 20th Jul 2012 at 00:09
eddy_gti6
Same paypal
You have pm Thumbs up
Posted 20th Jul 2012 at 00:15
eddy_gti6
eddiebeano
Where did you get your dash done Eddy?I have one sat in the garage waiting. I forgot to ask also. How dd the exhaust sound as it left Razz
team: Stealth Ninja
Posted 20th Jul 2012 at 00:17
eddy_gti6
Sounded class mate. Loved that exhaust. Might get same set up done for the VTS Cool
Lad down my way does it. £80 for my saxo dash but not sure how much a 306 dash will be? Al text you his number.
Posted 20th Jul 2012 at 00:20
eddiebeano
Cheers mate, may see about this next time in down Durham way, will have to pop in and see your new motor too Wink
team: Stealth Ninja
Posted 20th Jul 2012 at 00:24
eddy_gti6
Well am away for 2 weeks now. Just about to set off to manchester so give me a shout if your down in august and come for a look. Might have an engine by then LOL
Posted 20th Jul 2012 at 00:27
dav1
Eddy you interested in a 155bhp saxo with willwoods, omex, piper pulleys, Kent cams
Oz multi spokes the whole car loads good bits on 1500
230bhp 205 gti6
Posted 20th Jul 2012 at 14:51
chrisd306
no need the rally design discs if 205 brackets as its all to do with the offset just like my kads have the 205 brackets! there 285mm, R turbo 21 or 11 discs are ment to fit but i tried for long enough to try an find some, reason i punted them, an i bought the kads although they were ment to be gti6 brackets but after removing discs they were not!
if welly kit standard gti6 discs
& Audi Q5 S Line
Posted 20th Jul 2012 at 21:09
eddy_gti6
Calipers have came, need to check my brackets with a mate of mine who is also running wilwoods to see if the brackets are the same or not then will go from there.
Posted 4th Aug 2012 at 15:45
