Author Subject: Rear Axle stand placement Help!
daicarvideoguy
About to swap exhausts. Want the car on axle stands before I get undernithe it, but cannot see an obvious place for them to go at the back of the car.
Should I use the beam or will that knacker it?
Cheers Dai
Xbox Live: DaicarvideoGuy, Forza 4
Posted 25th Jul 2012 at 10:28
you can put them either side of the beam.
But there should be sill ones as there is at the front :s
Posted 25th Jul 2012 at 10:30
daicarvideoguy
Just found this thread http://www.306gti6.com/forum/showthread.php?id=146829
It didn't come up in the website search box but did with google how strange.
Anyway think I have a n answer
Posted 25th Jul 2012 at 10:31
Rear beam will be fine, it's rock solid and there's no weight at the rear of these cars anyway Yes
Posted 25th Jul 2012 at 12:06
Yep, jack up on the rear sill points and place the stands under the rear beam one each side. Wink
Posted 25th Jul 2012 at 12:32
Or as said there are sill points about 8" in from the rear, they have a little folded over tab on them, this would make access a little easier for you as the stands would be further apart, and more stable, which is handy when you are trying wrestle a reluctant exhaust off a car!
Posted 25th Jul 2012 at 12:33
davewagon
Where do you guys jack the car from when you want to put the stands under the sill points ?
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 8th Sep 2012 at 22:18
The beam/subframe, tripod ftw.
Posted 8th Sep 2012 at 22:39
fatlapit
Middle of beam
Posted 8th Sep 2012 at 22:51
davewagon
And what about for the front sills, where to jack then?
Spread weight with plank of wood or anything?
Posted 8th Sep 2012 at 22:59
Front just jack up the subframe from the mounting points and put the stands on the sill jacking points
Posted 8th Sep 2012 at 23:16
Jack the car on the sills then put the stands between the the 2 big bolts on the sub frame job done as for the rear well that comes up with the front so jack the car up from the front then put the axel stands under the rear sill points.
Posted 8th Sep 2012 at 23:20
