Author Subject: mis fire !!
skybluken
Hi guys, got amis fire problem at low revs, but as soon a u give it some it kicks through it and is fine just happen on tickover and lumpy when on low revs, not sure if could be plugs/coils or maybefuel pump. Just changed fuel filter last week after car would die andkick straight back in when puttin some fuel in and old filter was well manky. Any ideas would b good going to take plugs outand check them or just replace them. Thanks all
KEN
Diablo Phase 1 NOW DEAD
Alfa 156 2.0 JTS
Posted 27th Jul 2012 at 09:23
woody.
Could be one of many things:
- Lambda, doesn't work on WOT so could be to blame
- MAP sensor
- Idle control valve (stepper motor)
Read the FAQ on testing sensors and go round them with a multimeter and you should find the culprit.
Posted 27th Jul 2012 at 14:30
wilyoldave
Had something similar - turned out to be the lambda.
No more peugeots Sad
Snap - no more RS clioSad
Now Ph1 RS clio Smile
Posted 27th Jul 2012 at 18:25
BlackSix
dud you get this sorted in the end?
Posted 1st Aug 2012 at 23:23
skybluken
Not sorted yet got a new lambda. Not had time to fit it. More than likely goin to b monday. Will post the outcome hopefully that will sort it after the hours i spent reading on here :-)
Alfa 156 2.0 JTS
Posted 2nd Aug 2012 at 09:21
I would hazard a guess at the lambda being the cause. Yes
Posted 2nd Aug 2012 at 09:59
ian7675
Techno Viking
When you say misfire, do you mean it's popping or do you mean it's a cylinder that's not firing as some people call both of those symptoms the same thing?
Less than 24 hours to go!
Posted 2nd Aug 2012 at 10:05
skybluken
Just changed the lambda and reset ecu. Just done about 2 miles in it and seems ok will be goin out later doin about 20 miles so hopefully will be sorted. Old one was knackered all the end had split so i'm hoping were now sorted and my love affair with my 6 will be back on ;-)
Alfa 156 2.0 JTS
Posted 8th Aug 2012 at 13:10
Thsi reminds me that I need tojust work my way around the car with new sensors as im SO not up for s**t like this happening randomly
Posted 8th Aug 2012 at 13:19
Fingers crossed then. Thumbs up
Posted 8th Aug 2012 at 13:28
skybluken
Ok here goes car runs much better but still havin same probs. Fuel was low and then put a £10 of fuel in problem got better as fuel dropped problem came back noticed the fuel guage goin up and down so now thinking it could be a vacuum problem in fuel tank as i noticed a really long hiss when removing cap the other weekbut didint think much as weather hot. So removed cap and drove round for abit and its still there but not as bad. Fuel light stayed on as needle dropped and didnt go up and down as much which is making me think tank pressure! Cant find anything about air breather on tank. This has only got worse since i changed the fuel filter dont remember it being this bad before. Any ideas Please please :-(
Alfa 156 2.0 JTS
Posted 9th Aug 2012 at 10:57
You say you've changed the fuel filter, I take it you put the new one on in the correct direction of flow?
Posted 9th Aug 2012 at 12:56
skybluken
Positive but will double. But would of thought if that was the case it would happen all the time?
Alfa 156 2.0 JTS
Posted 9th Aug 2012 at 13:14
I agree. To be honest, it doesn't sound like a fuelling issue if it only happens at low revs and you go through it and then it clears...I suspect a possible fouled plug which only cleans up under higher rpm or a coil pack that is on its way out. Yes
Posted 9th Aug 2012 at 14:12
iplay
Clean the TPS Thumbs up
Posted 9th Aug 2012 at 14:21
skybluken
I'm thinking along the line of fuel tank breather/pump where its pulling fuel through andbuilding up a vacuum in the tank then it clearing causing it to die then breather opens giving the instant go?? Where is the breather cant find any thing on here normally its at the fuel filler neck i believe on other cars but cant see it??
Alfa 156 2.0 JTS
Posted 9th Aug 2012 at 14:23
skybluken
Changed tps & map sensors and was doin this before changed fuel filter but has got worse but seems to happen more when fuel low? Goin to fill the tank tomorrow when paid and see what happens
Alfa 156 2.0 JTS
Posted 9th Aug 2012 at 14:53
BlackSix
when you find out whats causing this, let us know mate. seems like im having the same symptoms.
i "fixed" it earlier, albeit temporarily, it was idling and running brilliantly but this evening it went back to the fault Sad
ive got some wiring damage on a few of the wires going to the sensors on the throttle body by the looks of it. all i know is i repaired a few wires there and it seemed to work but now its back.
il be checking my repairs tomorrow, but i cant be certain if id just moved another dodgy connection and its "slipped" again.
mines defo a wiring loom problem though, 100% now
Posted 11th Aug 2012 at 00:27
skybluken
Hi all, changed the coolant temp sensor the green ecu one(£12 gsf) after doin all the above. car is running like a dream. Me now back in love again. just need to sort my fuel breather now so running around with a loose fuel cap but it works for now and have an accurate fuel gauge. Cant beleve how quick this car now is after doin all this and how well it runs.
Thanks for all your help Ken
Alfa 156 2.0 JTS
Posted 16th Aug 2012 at 23:28
deano9621
glad you got it sorted buddy....had a few problems with mine ,but all's fine and running perfectThumbs up still love these cars thoughBig grin
french forever
T859HFC now goneSad
T534 KVR now new homeSmile
Posted 16th Aug 2012 at 23:41
I think they all hiss don't they if it's been ran down from a
Full tank?
Not sure if mine does or not but I've seen this happen with loads of cars ad it never made them run bad
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 16th Aug 2012 at 23:47
Glad this is sorted mate. Thumbs up
Now we just need to get your car fixed BlackSix...Yes
Posted 17th Aug 2012 at 08:52
