Author Subject: Side strip clips
parrotno1
Does any one know the part number for these? Cheers
Posted 30th Jul 2012 at 19:14
856540 20p each.
Posted 31st Jul 2012 at 23:19
parrotno1
Cheers, am I right in thinking they are different from phase 2 to 3?
Posted 31st Jul 2012 at 23:33
upto rpo 8210 6995X3 26p note to self don't just enter my vin when searching for parts for others.
Posted 1st Aug 2012 at 00:26
parrotno1
I'm confused, sorry for being a simpleton!
Posted 1st Aug 2012 at 19:03
There is a difference based on when car was made.
If you have a phase 2 car you need 6995X3 26p
If you have a phase 3 car you need 856540 20p
Mileage thread says 1999 so could be either. You referred to phase 2 so thought you had a phase 2 after providing the phase 3 part.
Simple question are the existing side stripes you need the clips for rounded and colour coded? If not it's phase 2 stripes.
Posted 1st Aug 2012 at 19:52
parrotno1
Phase 3 then I'll b needing. ,cheers thug puggin!
Posted 1st Aug 2012 at 22:14
parrotno1
The hole near the wing looks different to the rest of the holes, it's a small oblong where the others are a round hole, does that still take the same clip?
Posted 1st Aug 2012 at 22:15
Pretty sure I've read on here you need to use tiger seal/PU adhesive on part of the wing trim,could be wrong though!Dunno
Posted 1st Aug 2012 at 22:24
parrotno1
Sorry I meant the hole on the door nearest the Wing, noticed its oblong not round like all the rest?!!
Posted 2nd Aug 2012 at 08:33
No clip showing on Service Box for that holeDunno
Looks like trim should have a piece on it to pop into that hole?Dunno
Posted 2nd Aug 2012 at 21:16
parrotno1
Ok cool, cheers
Posted 3rd Aug 2012 at 23:03
Just to confirm there should be a small 'L' shaped piece of plastic on the door trims,which goes into the oblong hole first before clipping trim to door,you put this in then slide the door trim backwards before pushing clips inWink
So to remove the door trims correctly without snapping this offRoll eyes you need to start removing from the rear of door,then once the last clip is out of door slide the trim forwards to release the 'L' shaped piece of plasticThumbs up
You need door open to get it off without breaking itYes
Posted 16th Nov 2012 at 23:21
