Author Subject: removing brake cylinder and reservoir
russbez
wanting to remove it to get in with a wire buff
two nuts and pull the whole thing off?? seen there is some o ring seal i seen on pug part gateway
i imagine i will have to replace this if it falls to bits?
can i leave the reservoir attached? less things I damage or upset the better Yes
anything else to look out for? i.e left over brake fluid going everywhere??
My Rallye project thread
Posted 1st Aug 2012 at 16:08
master cylinder is attached by the 2x 13mm nuts. the reservoir is pushed in using the little seals but also has a clip through it. should remove easily though apart from that (assuming you've removed brake lines)
what are you wire buffing?
if you want to remove servo it's a bigger job, and done from inside the pedal box inside the car
Posted 1st Aug 2012 at 16:10
yup just two nuts, and of course the two brake pipes and fluid level sensor, there is a gasket but is usually reusable.
gasket where?
oh you mean little o-ring on the MC?
Posted 1st Aug 2012 at 16:13
russbez
yep brake lines are all off
wee bits of rust creeping in
thanks chaps thats pretty much what i wanted to hear
dont want to remove the big black servo thing.... its the thing with the rust i want to attack Smile
Posted 1st Aug 2012 at 16:16
I've found a lot of servos rusting because of fluid running down then from the MC leaking. worth changing the MC seals (or MC complete) if the servo is rusty from fluid
Posted 1st Aug 2012 at 18:43
russbez
ill have a look Cheers
pretty sure the small amount of fluid on the servo is from when i took brake lines off
Posted 2nd Aug 2012 at 13:53
