Author Subject: Changing axle bushes heeellllppppp
Moonstone6
Hi I have got one end of the axle down to replace bushes after hours or un seizing and I'm noticing the bolts which retain the mounts the one is fouled by the trailing arm please don't tell me I have to remove the torsion bars to move the trailing arm to remove the bolt to replace mounts your reply would be appreciated Taa lads
Posted 4th Aug 2012 at 17:15
yup if it has been lowered.
Posted 4th Aug 2012 at 17:25
jord294
As Mei said ^^^^
Posted 4th Aug 2012 at 17:38
Moonstone6
Job done I just managed by releasing the damper and using a bar to lever it so much difference using some fresh pug mounts the old ones were bo**oxed been a busy day Thumbs up thanks for the reply fellas
Posted 4th Aug 2012 at 20:41
matt evans
I was going to say you can do it by removing the lower damper bolt and forcing the arm down, we had to do that on Rich's lowered rallye when his rear mounts were fooked. Bit of a ball ache, the nearside, in comparison the off side was a 10 minute job...
honestly3k wrote:
owain wrote:
Posted 5th Aug 2012 at 21:48
Did this on my xsara VTS beam and the n/s bolt was fouled by the trailing arm just cut the old bolt out with a grinder and put a spare through the other way job done took 5 mins Wink.
Posted 5th Aug 2012 at 22:32
Moonstone6
o this is good news I was thinking only one side of my axle had been lowered Unsure mine was the same just undone the damper and the bolt wasn't Fouled by trailing arm
Posted 5th Aug 2012 at 23:06
Nah it's only the near side because of the position of everything. The VTS axle was at standard height which is about 25mm lower than a 6 one.
Posted 6th Aug 2012 at 09:07
