Author Subject: Had a go at a cam belt change
Well thought it was about time I tackled a cam belt change ? Never done one In the car and found it a little fiddly but not to bad all seems ok now it's back together and running Thumbs up
Followed the faqs from here Yes
Posted 5th Aug 2012 at 14:23
Nice one Bowen, well done. Smile
Posted 5th Aug 2012 at 14:33
Only snag I forgot to drain coolant - made a small mess when took water pump out Whistle
Posted 5th Aug 2012 at 14:38
720puggti
I can't believe you've never done a belt before Chris, I thought you were up on all mechanical work...
Deepak Gohil
Posted 5th Aug 2012 at 23:41
Congrats!
Big grin
Posted 6th Aug 2012 at 02:44
Awaiting "what went wrong?" thread....
Lol done loads of these engines now they look a lot worse than they are just need a known good bottom pulley!
Posted 6th Aug 2012 at 09:10
LOL
You'll know for next time though. Wink
Posted 6th Aug 2012 at 10:51
BlackSix
what method did you use fr the aux belt? looks like a right bugger tbh
Posted 7th Aug 2012 at 10:38
To change it or loosen it off to do the cambelt?
You only need to loosen the 2 x 13mm bolts holding the tensioner on and then unwind the 6mm allen head tensioning bolt and the belt will go loose. Yes
Posted 7th Aug 2012 at 10:42
BlackSix
cheers. doing mine at some point when i can be bothered lol.
Posted 7th Aug 2012 at 13:14
That's assuming you have the rallye aux set up ?
Posted 7th Aug 2012 at 15:36
BlackSix
Oh, no just. The standard 6 setup
Posted 7th Aug 2012 at 15:50
Then you will need to release the tensioner by using a ratchet and turning the whole thing to get enough slack on the belt Yes
Posted 7th Aug 2012 at 15:54
BlackSix
dont know what i was worried about. off and on in 15 mins Smile
thanks
Posted 7th Aug 2012 at 17:30
You did a belt change in 15 mins ?
Did you do water pump roller and tensioner ?
Posted 7th Aug 2012 at 17:45
ian7675
Techno Viking
...he did his auxiliary belt.
Less than 24 hours to go!
Posted 7th Aug 2012 at 19:07
BlackSix
just the aux belt mate.
Posted 7th Aug 2012 at 19:08
Ah I see that's pretty easy then once you release the tensioner. Try swapping the set up over to a rallye version and see how long it takes Yes
Posted 7th Aug 2012 at 19:34
BlackSix
i might do that actually, the piping and air con rad have already been removed by previous owner so it would make sense to get rid of the pump too. first got to sort the problems out though.
cambelt and water pump were done shortly after i got the car, aux belt was meant to be done at the same time but was supplied with the wrong part. went and got a refund on it and ordered the replacement but dealing with the fault i kinda forgot til they rang today and said the belt has been sat on the shelf ages do i still want it haha
Posted 7th Aug 2012 at 19:36
Good luck then you will need it Yes
Posted 7th Aug 2012 at 19:52
It's not that hard a task to change the setup over, just very fiddly and working in confined spaces. Wink
Posted 8th Aug 2012 at 08:43
