displaying posts 26 to 41 of 41
Pages (2): 1 [2]
Author Subject: Free bottom end
6waysforward
pete_rallye wrote:
I'd like this but not collecting it from Essex! If anyone happens to be heading from Essex to or past Yorkshire on the M1/A1 I'd happily offer you some petrol money for bringing it up!
Well i need a new rear beam so if you have a good one spare, i could meet you half way for a swap Thumbs up
Posted 2nd Oct 2012 at 22:35
pete_rallye
I have a beam and lots of new bits but it's very much a work in progress at the moment! Plus it's destined for my race car once completed...
Lap of the 'ring
Posted 2nd Oct 2012 at 22:56
pete_rallye
rikky wrote:
does someone pay you to kill engines pete? surely you haven't broken another?
Nope, just not fixed the other one(s) yet. Block is mashed so need a decent block, or 2...
Lap of the 'ring
Posted 2nd Oct 2012 at 22:57
ash
Six Addict
Pete I can pick it up and store it for you until you need it.
Posted 2nd Oct 2012 at 23:07
ash
Six Addict
.... Until you are passing!
Posted 2nd Oct 2012 at 23:08
I'm could also find a home for this Ash Wink
Posted 2nd Oct 2012 at 23:10
That sounds interesting, care to elaborate on that at all?
Posted 2nd Oct 2012 at 23:14
pete_rallye
Not much to elaborate on really. Its just a standard beam I have stripped, painted, and bought new bearings and seals for! Figured the one on my btcc car has seen better days so am building this one up to swap onto the car, if it ever works again. Then I had a kid, garage roof started leaking etc etc and so I haven't got round to putting it back together yet!
Ash, if you could, it'd be much appreciated, will be down south sometime!
Lap of the 'ring
Posted 2nd Oct 2012 at 23:31
So the Touring cars apart from camber and toe changes, ran a pretty much standard rear beam setup? Did they retain torsion bars etc?
Posted 3rd Oct 2012 at 00:15
pete_rallye
Post #35
Yep, although with the solution f shocks the tb didn't do much, but they do with the Penskes... there are a few other little additions to the beam also but nothing life changing.
Lap of the 'ring
Posted 3rd Oct 2012 at 08:02
Post #36
What thickness TBs and ARB are you running? Or is that classified? LOL
Posted 3rd Oct 2012 at 08:07
pete_rallye
Post #37
Nah, currently 23.5mm bars and the original touring car ARB which is like a sleeved standard bar. I'm not sure why they did the ARB like this, I can only assume regs. But I am likely to change ARB depending on circuit/conditions, as I have a standard bar, hybrid bar and 30mm bar, plus this original btcc one.
Might possibly change tb's too depending on circuits, depends a lot on if the shocks have the scope to cope with smaller bars in or not. Its going to be a lot of trial and error once it's up and running again, although a suspension place near me seems to be a firm believer that softer spring rates and thicker ARB's is the way to go, and has the results to back it up too.
Lap of the 'ring
Posted 3rd Oct 2012 at 08:13
Post #38
That rings true with a conversation I had with a guy from Aurok the Ohlins dealers, he was horrified when I told him I was intending to run 25mm bars and said with the right dampers there was no way I needed to run such a stiff TB. Interesting.
Posted 3rd Oct 2012 at 08:18
Post #39
What do you run up front? And do the touring cars use aluminium uprights or stock cast iron jobbies?
Posted 3rd Oct 2012 at 08:20
pete_rallye
Post #40
There's an adjustable blade style front arb with 2 different thickness bars. Hubs are standard iron jobs as per the regs.
Lap of the 'ring
Posted 3rd Oct 2012 at 11:40
pete_rallye
Post #41
Lap of the 'ring
Posted 3rd Oct 2012 at 12:32
Pages (2): 1 [2]
