Author Subject: moving air intake from behind radiator
markylee
Hi all I've been thinking of moving my air intake from behind the rad where it prob sucks in warm air to somewhere it can suck in cooler air. Has anybody done this, if so where did you put it and did you notice any results( pics would be good too), cheers
Posted 7th Aug 2012 at 21:01
So you think Peugeot had no idea where to put the air intake ?
Standard air box is best Yes
Posted 7th Aug 2012 at 21:10
Remove the fog put an intake setup there! Viper, 90 degree 76mm pipe and 76mm flexi hose to fog intake
Or mod your intake scoop to take air from just above the radiator grille
You won't gain any BHP but it'll make you're engine a bit more responsive
Posted 7th Aug 2012 at 21:12
markylee
gnrlee, do you mean run a pipe from the fog lightto the filter
Posted 7th Aug 2012 at 21:16
Ermmm,.. 2 secs
Posted 7th Aug 2012 at 21:17
markylee
Is that a yes
Posted 7th Aug 2012 at 21:20
not to a standard box no the standard's in and out vents are at the top and wouldn't reach to the fog properly,...
you could mod the scoop like,...
the previous owner of may car placed a K&N inside the original airbox this scoop and modded the bottom of the air box like so,..
my setup was,..
with a flexi hose leading to a trumpet in the place of where the fog hole is in the Grille,..
now I'm going to remove my bettery and relocate it to the boot and make use of the original air scoop hope this makes sense to you?
Posted 7th Aug 2012 at 21:30
markylee wrote:
Is that a yes
You just didn't.....
  • Posted 7th Aug 2012 at 21:31
    markylee
    Yeah it does, thanks a lot, do you not think that you'll still be getting warm air from the rad with the filter positioned there
    Posted 7th Aug 2012 at 21:33
    if you get something that's a closed filter like a Viper which is Carbon Fibre and isn't prone to heat soak unlike just a bare K&N behind the Radiator (open Filter) then it should be better off if the threads haven't been archived then you might find something using the search function Smile
    Posted 7th Aug 2012 at 21:41
    dangti6 wrote:
    markylee wrote:
    Is that a yes
    Laugh
    markylee
    Ok mate thanks for help, and sorry for the (is that a yes) remark
    Posted 7th Aug 2012 at 21:44
    don't worry about it! Wink
    have fun!
    Posted 7th Aug 2012 at 22:18
    Matt_rallye
    What about cheap enclosed kit? When I bought the Rallye it had a "pipercross" enclosed kit, but nowhere on it does it say it's a pipercross, was just told. Is it any good? And will it have any benefit to using it too a real pipercross open filter?
    Posted 7th Aug 2012 at 22:28
    miles
    Just use the std set up without any holes or silly cut out as this reduces the flow if anything, make sure you have a good filter, Green, PiperX.
    www.pugracing.com
    Posted 7th Aug 2012 at 23:11
    Matt_rallye
    I haven't got a standard setup. May have to go to the scrappers
    Posted 7th Aug 2012 at 23:21
    i'd just ask someone breaking a 6/Rally on here mate for the standard setup,..
    don't think you'll find it on many of the other 306's? Dunno
    Posted 7th Aug 2012 at 23:31
    Matt_rallye
    I'm sure ed doe had one kicking around, think I'm meeting up with him at the weekend so I'll ask him
    Posted 7th Aug 2012 at 23:35
    Standard airbox with a decent cold air feed will be best in terms of performance. Yes
    Posted 8th Aug 2012 at 08:42
    mik
    That pic of the K&N in standard air box opened up on the bottom looks as though it would suck in all kinds of nasties ( dirt, insects, gravel, small children etc) off the road. That must be great for engine life.
    Really, you want a setup that gets cold/clean air from as high as practicable - i.e. where the factory intake is. A lot of this aftermarket stuff is snake oil designed to get people to spend unnecessary money - those open K&N in engine bay with no ducting are sucking in hot air from behind rad and engine bay heat soak. Since the power loss is unnoticeable in normal driving and it is a bit louder people can persuade themselves that they are master engineers who had managed to make it faster than the factory did.
    Cherry Rallye SOLD
    Posted 8th Aug 2012 at 16:55
    I cut the snorkel on mine,and fitted a small plate to direct air,so air is fed straight into standard airboxThumbs up
    Fitted a RamAir filter inside the standard box and removed the stupid resonatorsWink
    Got a feeling its a pretty good set up,as my car did 180bhp with this airbox and Magnex system and de-catBig grin
    Totally agreeYes
    Posted 9th Aug 2012 at 15:28
    Thats my track car setup. Not perfect but not too bad.
    The shoes and clothes allow roundabouts to be navigated 10mph faster than normal too.
    Posted 9th Aug 2012 at 16:13
    eddy_gti6
    Nice way to dry your clothes Laugh my ass off
    Heres my set up
    Posted 9th Aug 2012 at 16:17
