Author Subject: G88 283's
JWP EFi
Turbo Legend!
seeing as the only option for brembos not to squeal is tarox G88, but do they have to be 288mm?
im assuming the 283's will be ok, can anyone put me right here?
Posted 7th Aug 2012 at 21:41
Did you not see my replies? 288!
Posted 7th Aug 2012 at 21:44
As above.
Otherwise the calipers/ pads will overhang.
Not even worth considering tbh
Posted 7th Aug 2012 at 21:47
Well maybe they won 't overhang .... but either way no.
Just no.
I wouldn't dick about with stuff like that. Just use the discs that are the right size
Posted 7th Aug 2012 at 21:49
Rich E Forum Admin
283x26 discs from a 206/207/307 are a direct fit and work fine with 406 Brembos.
That's what everyone ran years ago before someone discovered the Xantia discs fitted.
(The standard GTi-6 discs are a no-go though... wrong offset and too thin.)
I wouldn't exactly say that the Xantia discs are the 'right' size for the 406 Brembos. There's a large unswept area at the bottom, and an upswept lip at the top too as can be seen in Owain's photos here: http://www.306gti6.com/forum/showthread.php?id=141439
Posted 7th Aug 2012 at 21:57
Oh rly. In that case I'm a cock.
I thought that you needed 288s for the extra pad area or something.
Posted 7th Aug 2012 at 22:04
Rich E Forum Admin
The pads will overhang the discs very slightly (less than 1mm) when running 283s, but it's nothing to worry about.
The Xantia discs are the best compromise from a fitment perspective, but if you can get the 283s cheaply or have a set lying around then there's no point in not using them.
Whether the extra 2mm thickness and ~0.75mm extra pad contact area the Xantia disc will give are worth the trade-off in extra weight is an entirely different debate though...
Posted 7th Aug 2012 at 22:09
JWP EFi
Turbo Legend!
good point rich,
i know the wilwood 4 pot / 283 combo has overhang, recently had a car in the garage with this very setup, to be fair
there was a lip on the pads
Posted 7th Aug 2012 at 22:32
davewagon
What's the issue with having overhanging pads?
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 9th Aug 2012 at 09:19
JWP EFi
Turbo Legend!
the pads won't wear evenly, hence there will be a lip. They will start to break up, i saw an example
of this very recently
Posted 9th Aug 2012 at 20:34
davewagon
Ah didn't consider this, cheers!
Posted 10th Aug 2012 at 07:46
