Author Subject: XU10J4RS engine (pics added)
24seven
I bought a Xsara VTS engine to use as a uni project, with the intention of ending up with a rebuilt standard engine to go into my 309. Since the 309 is no more I may as well sell this. It's the engine and loom from a phase 1 VTS, no gearbox, no ECU. 117k, non-tapper, no smoke. (Original ad can be seen here).
In my ownership it hasn't turned under it's own power and has been kept clean and dry indoors in one of the uni workshops where I have made sure to oil and crank it manually occasionally while it's in one piece. It was stripped from the Xsara by a krisb on here.
I've also got a spanking new idle control valve a VSS sensor needed for the speedo drive in a 205/309 conversion and almost-new BBM lower and gearbox mounts that I'll throw in with it as it's all of no use to me now.
£300 the lot to your door or £220 collected from Swansea
Conveniently it's still on the pallet from when I took delivery if you want to arrange a courier.
Posted 12th Aug 2012 at 20:36
24seven
BBM gearbox mount has now sold separately.
Posted 5th Sep 2012 at 18:34
24seven
Relisted.
Posted 8th Sep 2012 at 11:05
24seven
bump
Posted 12th Sep 2012 at 14:31
24seven
SOLD
Posted 13th Sep 2012 at 16:18
