This is the backbox off the previous system which was on the car when I bought it 2 years ago. It looks like it's got a bit of metal right in the middle. Is this normal??
and the backbox in question, anyone seen one like this before? :
| Author | Subject: Is this normal? |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
I've just fitted my Jetex exhaust to the 6 after buying it about 10months ago This is the backbox off the previous system which was on the car when I bought it 2 years ago. It looks like it's got a bit of metal right in the middle. Is this normal?? ![]() and the backbox in question, anyone seen one like this before? : ![]() Cheers |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
Nope, bet that was sapping power.________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
woody.
Yeh thought it was feeling sluggish! I've wacked that a couple times with a ratchet and it's fooking tight as well |
mpieczko
Regular Location: Birmingham Registered: 11 Mar 2009 Posts: 236 Status: Offline |
This is often how exhaust silencers are laid out.In the second picture, look at the lateral offset between the input and output pipes. The blind pipe forces exhaust gases to find their way out of the box by passing radially out through the perforations and baffles then out through the output shaft. Yes, you will inevitably get a certain amount of back pressure due to such an arrangement. If you want to go faster don't fit a silencer box. |
woody.
So in other words its pretty sh*t!? Cheers for the explanation mate, the box isn't damaged inside and feels pretty solid so its obviously meant to be there |
its not s**t, its just a standard replacement jobbie.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
woody.
So are the standard boxes the same design as what mpieczko said? |
swiftyboi006
Well thats not an o/e exhaust so its not the same________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
Explanation of your common silencer design________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
woody.
I understand, cheers for the link. I'm liking the jetex exhaust at the mo so quite glad to see the back of this |
