Author Subject: MI16 compression
peugeot96
What is the healty crank pressure on a MI16 2.0 engine?
Posted 18th Aug 2012 at 21:43
Posted 18th Aug 2012 at 21:45
peugeot96
My is around 250, but that is with 0.5mm block decking (xu10j4). Is that to high?
Posted 19th Aug 2012 at 12:32
erm Blink
have you confirmed camshaft timing is correct?
Posted 19th Aug 2012 at 14:52
peugeot96
erm Blink
yes the timing pins are spot on. Also the comp test was done with regrounded cams and a 4pulley inlet and 2pulley exhaust. But today i fitted a 3pulley on the inlet. I guess that will lower the comp a little bit.
Have you tested the comp on a mi16 engine with with uprated cams and higher comp?
Posted 19th Aug 2012 at 21:04
