displaying posts 351 to 375 of 516
Pages (21): first .. 14 [15] 16 .. last
Author Subject: DemonDriverDan's Race Rallye Project
Post #351
only needs to come off 16mm!
Posted 20th Jun 2017 at 11:58
Post #352
The dowels are only for alignment, if they're letting your gearbox bolts come loose then the box was already moving anyway (I.E. Bolts already loosening).
If it's running rich have you checked the plugs + filter, especially with that power loss?
Posted 20th Jun 2017 at 12:34
pug_306
Post #353
I've had a few 205 and 306s with no dowels in and the bolts coming undone. Fitted new dowels and bolts and has been fine. They take alot of stress off a bolt too.
1992 205 GTi6
205 Turbo 340bhp
Posted 20th Jun 2017 at 12:50
Post #354
They're a split dowel, they won't take any real loading unless the face is already slipping (which means the bolts are already loose)
Posted 20th Jun 2017 at 12:57
Post #355
they may only be for alignment, but they do come loose without them in place...
maybe the input shaft being offcentre introduces a vibration and a rotational force on the bellhousing that makes them come loose?!
Posted 20th Jun 2017 at 13:46
demondriverdan
Post #356
Oil filter was done in January, about 60 miles ago. I've not done the fuel filter in a while thinking about it, probably worth doing that.
WP, to separate the box I still need to drop the fluid, remove N/S driveshaft, undo the mount, lower it all enough to actually move the box out enough. A couple of hours of work that I don't have time for!
Rallye Race Car
Post #357
If it's rotating, the bolts are already coming loose. The only way it would make a difference would be if you were missing enough that the gearbox was no longer going up square so the input shaft wasn't true to the crank, then the extra vibration would loosen things. Either way, they still don't take any loading.
Posted 20th Jun 2017 at 15:07
Post #358
Hope you get it sorted Dan Thumbs up
Posted 20th Jun 2017 at 18:23
devere
Post #359
Don't worry dan. I put my repaired gearbox in last Wednesday evening. Then had to take it out again on the thursday! So at least your getting more use out of it than that!
I can get the car from 4 wheels on the floor to box on the floor in dead on an hour now it's so regular!
Posted 20th Jun 2017 at 22:51
demondriverdan
Post #360
I took the box out 2 weeks ago to put a new clutch in. Then took it out again 5 days ago to replace that clutch for another new one, I've done it enough recently! I would fix it and have ordered the parts to do it but I have a huge list of other stuff that needs doing first.
I'll threadlock the remaining bolts and check they're all still present during and after quali.
Rallye Race Car
Posted 21st Jun 2017 at 09:16
demondriverdan
Post #361
Success! It survived the weekend and ended up with a reasonable result (before a stupid penalty anyway). Few issues cropped up, mainly with engine running which I'll start a dedicated thread for, but otherwise everything survived. I did manage to shear the bleed screw on the thermostat housing though, resulting in a bit of a bodge but it worked Smile Also got an issue with the rear tyres rubbing on the inner arch which they haven't before. I'm planning on getting some camber put on the rear anyway so this will be more of a problem in future. I think the best way to solve this is to see if I can get the arch moved inward a bit.
Rallye Race Car
Posted 26th Jun 2017 at 15:33
blandy
Post #362
Was watching the timings to see how you got on. I feel your pain ref the bleed screw i did exactly the same on a track day lol
Posted 26th Jun 2017 at 15:50
demondriverdan
Post #363
It was such a stupid thing. Wasn't really paying attention then I thought "this seems to go further than normal" then snap. Luckily I found a bolt in a random collection of stuff in the truck that fitted (after being cut down) and away I was. I'll buy another, proper bleed screw again though, just to be safe.
Rallye Race Car
Posted 26th Jun 2017 at 15:54
fatlapit
Post #364
I run 205 40 17 with 3 degrees with 20mm spacers ok dan, I have about 10mm left to play with too with no mods to the arch. maybe your axle has moved
Posted 26th Jun 2017 at 16:53
demondriverdan
Post #365
Axle isn't a bad shout, I'll have a look.
I don't want to space the rear at all, would rather have the arches moved than push the wheels out.
Rallye Race Car
Posted 26th Jun 2017 at 16:55
Post #366
has it ever been rebuilt?
Posted 26th Jun 2017 at 21:48
demondriverdan
Post #367
Nope, completely standard other than new TBs and ARB. I'm slowly rebuilding a spare axle to fit with new bearings, shafts etc. so maybe I should speed that up a bit!
Rallye Race Car
Posted 27th Jun 2017 at 09:18
Post #368
definitely!
Posted 27th Jun 2017 at 10:36
demondriverdan
Post #369
Plan is to move to a 30mm ARB with 0 toe and 2 degrees of camber. I'm still uncertain of the camber value, maybe 2.5 degrees. I need to look in to how that will change the car's handling.
Rallye Race Car
Posted 27th Jun 2017 at 10:41
Post #370
camber specifics wont alter handling that much, it will effect how it works the tyres, that's what will determine the camber you need.
toe has more of a direct effect on turn in and stability, touring cars ran a significant amount of toe out, many people can't handle them!
Posted 27th Jun 2017 at 13:07
demondriverdan
Post #371
Yea I'm not brave enough for big amounts of toe out, 0 should be enough for me! Good point about camber, I run 2.5 up front so maybe 2 at the rear will be better
Rallye Race Car
Posted 27th Jun 2017 at 13:17
Post #372
depends on tyres, stock is 1.3 ish.
Posted 27th Jun 2017 at 13:22
demondriverdan
Post #373
205/50/16 DZ03Gs. More camber will potentially give me more arch issues but maybe the beam fix will help that
Rallye Race Car
Posted 27th Jun 2017 at 13:27
Post #374
A lot of the massive toe out on touring cars is to help generate heat in the rear tyres, not so much of an issue on anything short of full race slicks.
Posted 27th Jun 2017 at 18:56
fatlapit
Post #375
Dan
You see the f2000 spoiler, can you use it with the oe one? also how did you mount it to the boot???
Posted 3rd Jul 2017 at 16:38
