Author Subject: wiring for high boost fuel pump
russbez
i am in the middle of wiring and routing in my swirl pot
can anyone confirm that the blue wire is the live i need to cut and solder in another wire to use as the live trigger wire for my relay
My Rallye project thread
Posted 21st Aug 2012 at 19:50
russbez
and can anyone recommend a live to use for going to the relay, as my main live for powering the bosch fuel bump
i have thick gauge wire at the ready
one or two people mentioned using a live from back of ECU area Unsure
a live on the fuel cut off switch perhaps?
or run a live from battery (fused of course)
hope this makes sense i wrote it in a rush LOL
Posted 21st Aug 2012 at 22:25
You could take the power for the relay directly from the battery via a suitable fuse.
Posted 22nd Aug 2012 at 08:12
sorry mate, can't help as rich fitted mine, I can look and take some pics though if you need any?
I'm not sure where the feed for mine comes from.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 22nd Aug 2012 at 08:42
russbez
thanks Jim, confirms what Rich just pm'ed me LOL
i think i sorted both queries, thanks again though Andy.
more time online to search and i found it straight away...
simgti6 wrote:
engine fusebox, fuse 9 (15amp) blue wire 121 is the fuel pump live
this is the wire I used to power the relay for the bosch 044 pump
Posted 22nd Aug 2012 at 08:46
Just make sure you feed the open contact not the coil or the fuel pump will be constantly on.
Posted 22nd Aug 2012 at 08:57
russbez
the "open contact" on the relay?
i plan to use a 30amp relay as i already have one
basically when my standard fuel pump kicks in it will trigger the relay to complete the Bosch 044 circuit thus both fuel pumps will go at same time.
pretty sure i understand enough electrics to not blow anything up
to use correct gauge wire, 30 amp fuse for the Bosch live wire coming from battery to relay
will solder and heat wrap any wires so it does not look too rough
this seem okay?
Posted 22nd Aug 2012 at 09:35
russbez
LOL
(not mine, stole it off the internet)
Posted 22nd Aug 2012 at 09:46
Yup, thats how i'd do it Wink use the bloue wire as the trigger for the relay and you wont go wrong really. Cant say the pin numbers are correct on the relay without having one to hand but diagram is fine. (well stolen sir) lol
Posted 22nd Aug 2012 at 13:42
russbez
thanks.
Posted 22nd Aug 2012 at 15:26
pete_rallye
That blue wire goes right back to the maxi fuse box. Can't remember which fuse it is but its obvious if you look underneath because the blue wires there. You could splice into it there, attach the relay onto the maxi fuse box so it's protected and easy to get too, and also easy to run a cable from the battery, through the relay, then under the car to the new pump.
The 044 pumps draw 14a at 5 bar, and 15a at 8bar, so probably a 20a fuse to be safe and avoid nuisance fuse blowing, or a 15a one should be ok but under heavy load the pump may blow it. As long as the cable your using is rated above 15a it should be fine.
Lap of the 'ring
Posted 22nd Aug 2012 at 22:05
russbez
Thanks Pete, putting the relay in the fuse box sounds like a good idea.
Should be easy to find that wire and solder/splice into
Posted 23rd Aug 2012 at 10:41
russbez
for anyone whos interested
fuse 9 ; spliced it successfully
relay located in fuse box with live running along next to abs wires to rear of car
(havent secured these yet)
both fuel pumps are priming okay.
update : works great
Posted 27th Aug 2012 at 14:15
