displaying posts 26 to 50 of 57
Pages (3): 1 [2] 3
Author Subject: rad weld to fix matrix???
stan_306gti6 wrote:
What happened to all those people who chose to go without, did their engines all boil themselves? LOL
Only those who went high boost on their Model T Fords yo
Posted 26th Aug 2012 at 13:22
Matt_rallye
http://306oc.co.uk/forum/thread-4363.html?highlight=heater+matrix
Ruan knows his s**t, at a guess it would be the same for the '6 as you would be loosing a 1/3 of the cooling system
Posted 26th Aug 2012 at 15:03
nope, he's wrong I'm afraid, if you bypass its fine, blocking the pipes is another matter.
Posted 26th Aug 2012 at 15:06
^^This. Thumbs up
Posted 26th Aug 2012 at 15:22
Exactly. I bypassed mine ages ago and have done several trackdays since, never been above 90 degrees.
Bypassing the matrix is not a problem.
Blocking the holes I agree could be a bad idea, but as for bypassing it - how much heat does he think you lose by pumping water through a heater matrix with no air moving over it Dunno
Posted 26th Aug 2012 at 15:28
swiftyboi006
Does certainly make sence owain and how is a heater matrix 1/3 of the cooling system
Black p3 Love
Posted 26th Aug 2012 at 17:56
miles
Blocked mine on 8 and 16v Pug engine's, never had a issue at all
www.pugracing.com
Posted 26th Aug 2012 at 18:03
Precisely. Yes
/thread
Posted 26th Aug 2012 at 18:09
swiftyboi006
quote:
Ruan knows his jack s**t, at a guess it would be the same for the '6 as you would be loosing a 1/3 of the cooling system
Black p3 Love
Posted 26th Aug 2012 at 20:21
Post #35
So...
Based on the above, what's the verdict then? Are you going to use Radweld or not? LOL
Posted 27th Aug 2012 at 09:58
swiftyboi006
Post #36
I think wen i get the blowers going il try some, depending if im in the mood to take the dash out. If i can book a day off work then ill take the dash out. Anyone know how much a matrix is? And what one i would need? Air con been taken out p2
Black p3 Love
Posted 27th Aug 2012 at 10:06
Post #37
Valeo for non-aircon, GSF for about £30 iirc.
Posted 27th Aug 2012 at 10:47
Post #38
Youll still need an aircon matrix unless someone swapped the heater box
Posted 27th Aug 2012 at 10:57
Post #39
Behr then.
Posted 27th Aug 2012 at 10:58
rallye1999
Post #40
I've got a rallye heater box and year or two old matrix if needed
Posted 27th Aug 2012 at 11:19
Matt_rallye
Post #41
Well I stand corrected then lol
Posted 27th Aug 2012 at 11:34
Post #42
hole in the bulkhead and a lot of the wiring that is secured to the underside of the dash is also different, i.e don't bother LOL
Posted 27th Aug 2012 at 11:41
miles
Post #43
The old 'You need a Matrix thing' is only if you have a Mini (Proper one) and get stuck in traffic to keep the heat down, Other than that someone should point out to him that a Radiator is designed to cool coolant and the heater to heat the cabin
www.pugracing.com
Posted 27th Aug 2012 at 11:52
Post #44
Pretty much sums it up. Yes
Posted 27th Aug 2012 at 15:35
swiftyboi006
Post #45
Made my mind up im going to try the rad weld as ive read up alot on it and seems to fix small leaks, if it doesnt work ill be doing the matrix properly.
Black p3 Love
Posted 27th Aug 2012 at 18:03
720puggti
Post #46
Hi Olly,
I've used K-seal in the past. No issues...
Deepak Gohil
Posted 27th Aug 2012 at 18:10
swiftyboi006
Post #47
K-seal? Is this everyday stuff that can be bought anywhere? Would you recommend this over rad weld?
Black p3 Love
Posted 27th Aug 2012 at 18:26
24seven
Post #48
K-seal is named after the K-series engine (supposedly). The "rad-weld will definitely gunk up your engine and kill it in a ball of fire" myth is complete bo***cks. The stuff has been around for a LONG time, which it wouldn't have been if it was as problematic as people think. People think it lines the entire cooling system and narrows it down slightly, which can block areas that are thin anyway. This is rubbish. It dilutes through your entire cooling system and when exposed to air at the point of the leak, it dries and seals the hole. the rest of it remains as a liquid until it either find another leak, or you flush it out. People *have* found it to completely block pipes, but if your cooling system has been bled properly you won't have the air bubbles in there that causes this.
I don't know if K-seal works the same way, but it seems to be the more popular of these type of products, although it's more expensive off the shelf, but try eBay.
Posted 27th Aug 2012 at 18:55
swiftyboi006
Post #49
Just bought sum Thumbs up
Black p3 Love
Posted 27th Aug 2012 at 19:28
24seven
Post #50
Make sure to follow the instructions properly. a lot of people just chuck it in without reading them.
Posted 27th Aug 2012 at 20:06
Pages (3): 1 [2] 3
