displaying posts 26 to 41 of 41
Pages (2): 1 [2]
Author Subject: six stalling
JWP EFi
Turbo Legend!
woody. wrote:
Another vote for the power steering sensor too. Give the ICV a good clean and see if it helps at all (in my experience you'll have to replace it if its broken anyway). The power steering sensor is down between the rad and the inlet manifold, unplug that to see if it gets any better, if it does, replace it. Good luck!
well if doing the above cures it then why replace sensor? i will unplug sensor before i go to work tomorrow see if
it behaves
Posted 5th Sep 2012 at 22:58
Its not going to run perfect without one though.
The revs will probably dip when you turn the wheel without one i think?
Posted 5th Sep 2012 at 23:15
JWP EFi
Turbo Legend!
quick blip and your sorted Wink
Posted 5th Sep 2012 at 23:17
blandy
Again mines disconnected (wire broke) but doesn't seem to give any ill effects?
Posted 6th Sep 2012 at 06:23
It should be there though (and working).
It just helps out with the strain put on the engine during slow speed turning and compensates. You can blip the throttle yes, but it was designed so you do not have to do this. Smile
Posted 6th Sep 2012 at 21:17
pug pete
I think my air con fcuked az wines like a b**ch have get that sorted as well
Posted 6th Sep 2012 at 21:22
JWP EFi
Turbo Legend!
earlier today i unplugged my PAS sensor and now the idle is perfect! i'm just going to leave it this way
Posted 6th Sep 2012 at 22:04
Do you only get the 'whine' whilst the AC is engaged? Dunno
Posted 6th Sep 2012 at 22:18
pug pete
na all the time pump had it thinkUnsure
Posted 6th Sep 2012 at 23:31
JWP EFi
Turbo Legend!
Post #35
a/c clutch bearing f**ked. rallye aux setup ftw
Posted 6th Sep 2012 at 23:48
woody.
Post #36
it behaves
Tbh I'm being a hypocrite, I unplugged mine a couple months ago which solved the idle but I haven't got round to replacing it either. Hasn't ever stalled when on full lock and parking. Still having slight hesitation issues with mine so I'd like to get that sorted before buying anymore god forsaken sensors Roll eyes
Posted 7th Sep 2012 at 00:05
Post #37
Well it could be the viscous clutch on the compressor which is causing it, or more likely it will be a roller/idler on the aux belt circuit as these are very common to fail and get 'noisy'. Yes
Posted 7th Sep 2012 at 13:06
pug pete
Post #38
Up date think got my six running spot on now me in let manafold had gone Big grin
Posted 3rd Aug 2013 at 23:57
Post #39
Inlet manifold had 'gone'. Can you explain this further? Dunno
Posted 4th Aug 2013 at 00:11
pug pete
Post #40
It would help lol ment inlet gasket sorry Thumbs up
Posted 4th Aug 2013 at 00:28
Post #41
Cool, glad it's all sorted. Smile
Posted 5th Aug 2013 at 08:17
Pages (2): 1 [2]
