Author Subject: Cam Sensor
speedo306
What problems do you encounter when the cam sensor is not functioning properly or faulty.
RJ
Posted 6th Sep 2012 at 04:06
jeffers Forum Admin
Moved to a more appropriate section.
Team Running Engine again!
Team Negative Camber!
Posted 6th Sep 2012 at 07:46
It will take ages to start as the engine uses the cam sensor as a reference for engine position during the starting phase only. Once it's running, it is not used. Wink
Posted 6th Sep 2012 at 07:51
fatlapit
thought it was used for the sequential ignition or something!!
Posted 7th Sep 2012 at 17:42
No
Posted 8th Sep 2012 at 10:44
fatlapit
Oh ok
Posted 8th Sep 2012 at 10:54
It's a strange one really, because the lower spec head (which uses the one long coil pack) has the casting for the cam sensor but doesn't have the hole cut out for it...
Posted 8th Sep 2012 at 11:06
fatlapit
Juch rich w said it uses it as a trigger for the sequential bit.
Posted 8th Sep 2012 at 11:23
Interesting...Rich knows his stuff, will have to ask him about this. Yes
It has been under intense discussion before and the end result was that it was used only for starting, will double check. Wink
Posted 8th Sep 2012 at 16:01
