Author Subject: Standalone ecu
peugeot96
Can somebody recomend me a good standalone ecu. lm sick and tired trying to remap my MP3-2 ecu. Was on the dyno yesterday for remap nr.2. Everything looked ok on the rollers, but this morning the cold start was way to rich. Did run the engine warm, taked all the plugs out and cleaned them. Then l replaced them and drived 3-4 km and took them out and they had started to be black again.
Posted 8th Sep 2012 at 21:37
Dta Smile
But depends what your mapper preffers, cold start is slways a little tricky unless you have done several engine builds along the same kind of spec.
Posted 8th Sep 2012 at 21:39
Another vote for DTA, although I'm biased as I run one. Yes
Posted 8th Sep 2012 at 21:41
Never had any issues with the DTA units, but as Welsh says, coldstarts take quite a bit of time to fine tune usually.
Posted 8th Sep 2012 at 21:43
DTA here also. I was impressed with the amount of features the bottom of the range S40 offered.
  • Posted 8th Sep 2012 at 21:47
    I use the S60 Pro and also very impressed with the features within the system. Yes
    Posted 8th Sep 2012 at 21:50
    Anyone with an S80 care to p**s on Stans parade?
    LOL
  • Posted 8th Sep 2012 at 22:09
    How come you have one stan? I didnt think you would need one
    Excuse my ignorance im not up on ecus etc
    Posted 8th Sep 2012 at 22:16
    crossflow
    I would highly recommend the Predator ECU plug and play into the standard loom and fully mappable what ever mods you have turbo, n/a or supercharger, very user friendly to use. p'm me if your interested
    Posted 8th Sep 2012 at 22:44
    LOL
    Wave
    Posted 8th Sep 2012 at 22:52
    LOL
    LOL
    Trust you Dan...
    Posted 9th Sep 2012 at 08:09
    I use one as the Super High Boost setup is different to the normal low/high boost layout, therefore you can't use the standard ECU anymore.
    Plus the DTA is so easy to use and you get more accurate results from it. Yes
    Posted 9th Sep 2012 at 08:12
    miles
    I tend to use Omex on all of my car's, Good system and easy to map plus allot of people in the UK at least knows the system,
    But as always use the system your RR likes to use, knowledge base helps allot
    www.pugracing.com
    Posted 10th Sep 2012 at 19:47
    bas_306gti
    I've used KMS MP25 on MI16 engines, not that expensive and works really good.
    Posted 10th Sep 2012 at 20:17
    pete_rallye
    DTA for me too, had an S60, now got an S80. Software is dead intuitive, you could literally work it out just by messing about with it for a while. I didn't find the Omex software as good, but have used their ecu's before with no issues. There is a DTA forum too with some knowledgeable people on it which also helps!
    And yeah, cold start is a pain, even more so with big throttle bodies as air speed is so low on cranking, and then as soon as the engine has run, even if its just for a few seconds then you can't do it again for a good hour or so. I used to start mine, check plugs, alter map and then come back a few hours later and try it again, took ages to get it right.
    Lap of the 'ring
    Posted 10th Sep 2012 at 23:17
    My coldstart isn't perfect, but it's pretty good and I'm happy with it. Just takes a few more cranks than normal to fire and then runs sweet.
    Posted 19th Sep 2012 at 09:17
    Mine would be a bugger to start unless I pressed the throttle a bit, as soon as it fired it was away but starting from cold with a closed throttle just wouldn't happen. (I was on Omex but that's a symptom of mapping not the ecu)
    Posted 19th Sep 2012 at 09:41
    I can start mine from cold with the throttle closed, but it just takes a few more cranks than it did when it was standard. Yes
    Posted 19th Sep 2012 at 16:59
