Author Subject: NGK lambda any good?
dan86
Just picked up an NTK lambda sensor for my 1.8 XS as I think it might solve a hesitation issue. Are NTK sensors any good?
Posted 11th Sep 2012 at 16:41
bosch are o.e on pugs and you can pick them up for about 50-60, I think NTK are o.e on many other manufacturers though like ford.
Posted 11th Sep 2012 at 16:44
mattgti6phase2
Very much the same. As welshpug says bosch are O.E for pug and iirc they invented the lambda sensor. NTK are a very reputable name though so it'll certainly do the job Yes
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 11th Sep 2012 at 16:48
dan86
Thanks for the info lads Thumbs up I'll fit that tonight then.
Posted 11th Sep 2012 at 17:02
Fitted one to mine last weekThumbs up
£20 E-Bay bargain brand spankingWink
Works spot on,car feels smoother now so thinking the old one was starting to failSmile
Posted 11th Sep 2012 at 20:47
mattgti6phase2
Mine came up with O2 sensor permanent fault. A new one seems to have cured it.
5 x a 306 owner!
Posted 11th Sep 2012 at 21:42
dan86
That's good to know mate. I'm always a bit unsure about anything non oem or aftermarket.
I get a slight hesitance when pressing on sometimes like the ecu is taking a while to decide what to do. It also loses a noticeable amount of power above 5500rpm quite often. I've changed the plugs and coil pack which improved things but not cured it.
I unplugged the o2 sensor which has made quite a difference. It felt like it produced more power than before and happily went to the redline. I do get a few pops in the manifold/downpipe on over-run though. I'm not using the car like this as I don't want to poison the cat or pollute the oil if its too rich.
Posted 11th Sep 2012 at 21:48
My red 6 started juddering and spluttering like a b**ch when driven gently, got the codes read and lambda was fooked. Got an ntk one from a factors for about £45 and it cured it spot on. Was fine till the day I sold it. Got a new genuine bosch on the supercharged beast though just as I know it's O.E.
Posted 11th Sep 2012 at 23:08
I would prefer a Bosch purely because it's O.E. Yes
However, NTK are a very reputable brand so I can't see you having too many issues with it.
Posted 12th Sep 2012 at 10:41
mattgti6phase2
They make bloody good spark plugs so don't see why they couldn't make a good lambda. My new NTK one seems to be holding up fine so far Yes
5 x a 306 owner!
Posted 12th Sep 2012 at 11:44
Yeah, it's a strange one...
I always prefer Bosch lambdas, but then I run NGK plugs myself too. LOL
Posted 13th Sep 2012 at 11:39
seans6
Wheres the cheapest place to buy a o.e Bosch one?
Posted 13th Sep 2012 at 12:03
Posted 13th Sep 2012 at 12:30
seans6
Ok thanks welshpug Smile
Ill be ordering the direct fit later, cba faffing.
Posted 13th Sep 2012 at 13:02
Any factors should be able to order you one from Bosch direct. Yes
The shocking thing is, you can buy a Bosch sensor in a Bosch box for around the £60 mark from a factors, and yet you can buy the identical Bosch sensor in a Peugeot box from Pug for around the £140 mark! Shock
Posted 13th Sep 2012 at 13:05
