Author Subject: roof gutter trims??
what holds these in place, should the rubber under them be wide enough to grab the sides wedging it in somehow?
i removed them to polish the car a few weeks back and discovered them in my garage earlier, so off i went to fit them except now they are loose, they literally just sit on the gutter, and 1 even bows upwards ever so slightly, has the rubber shrunk while its been garaged or somthing, they was much tighter before, just wondering if theres somthing i dont know before i bloody glue them down
thanks andy
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 11th Sep 2012 at 20:14
grumpychef
The Rib Man
they just perish a bit and don't fit properly again i lost one once ... about £7.00 for a new one. i replaced the pair with snug fitting new ones
Formally team BLAZE now Team bianca recuperating from multiple organ failure nicely!
items replaced so far, clutch, cambelt etc, radiator, exhaust, most of front running gear, wish bones, drop links, ball joints, track rod ends, bearings, brakes, calipers, discs, and pads, brake lines, front springs, brake balance compensator thingy, hand brake cable, throttle cable (twice), coil pack, door handle, windscreen, wipers, head lamps several sensors and bulbs Dry .rear beam new throttle cable, new battery. .......... yeah man, team money pit! but shes still rollin!
Posted 11th Sep 2012 at 20:17
Doh so they have dried up in the garage and shrunk or somthing, do pug still sell these i thought it had been posted that theyre no longer available.
i think it looks much better with them
Posted 11th Sep 2012 at 20:22
Ed_van_dijk
Bit of mastic will hold them in again, that's what I done
Astor 6
Posted 11th Sep 2012 at 21:00
Moved to Exterior. Smile
Posted 12th Sep 2012 at 10:52
Niall
You can bend them back to shape and they normally fit well after. They have a slight bend to them to follow the roof line but when you remove them from one end, you normally end up bending them straight.
Posted 12th Sep 2012 at 14:20
footah212
looks better without themLOL
Replaced mine twice with ones from scrappy > they are now lying on a motorway hardshoulder somewhere
Saves weight too.Thumbs up
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 12th Sep 2012 at 14:31
i forgot these was loose, not sure if theyre still on the car as i nipped to mc d`s earlier
Posted 13th Sep 2012 at 21:28
