Author Subject: Recommend a decent track fluid?
braymond
And also put "dot" into laymens terms.
Thanks
Rallye-R
Nurburgring article
Posted 20th Sep 2012 at 11:46
Ive got ap racing 600 in one of my cars and ate super blue or whatever it's called in the other. Not had fluid issues in either whilst on track, ruined many discs though.
Posted 20th Sep 2012 at 12:29
http://en.wikipedia.org/wiki/Brake_fluid
Posted 20th Sep 2012 at 12:31
Dot in laymans terms:
Use DOT 4, or DOT 5.1, don't ever use DOT 5
Wink
Posted 20th Sep 2012 at 12:35
haven't you got that wrong way round phill?
Posted 20th Sep 2012 at 12:51
clen666
As in don't use dot 5?
Team 'unintentional rat look'
Posted 20th Sep 2012 at 12:56
mr swampy s16
**BAD SELLER**
Ate blue for me
Posted 20th Sep 2012 at 13:10
braymond
Ok, so DOT 3, 4 & 5.1 is Glycol based, and DOT 5 is Silicone based (thanks for the link WP) That would suggest to me that 5 is one to avoid yes?
Rallye-R
Nurburgring article
Posted 20th Sep 2012 at 13:19
You never saw nuffink LOL
Posted 20th Sep 2012 at 13:25
braymond
LOL
Rallye-R
Nurburgring article
Posted 20th Sep 2012 at 13:27
clen666
What if it's a completely new system, ie new clean pipes? Would you still avoid dot 5?
Posted 20th Sep 2012 at 13:43
Yes
It gives a slightly spongey pedal and you tend to find any water that does make it's way into the system sinks and sits in the bottom of the calipers...
Posted 20th Sep 2012 at 13:45
clen666
Thumbs up
Posted 20th Sep 2012 at 13:48
braymond
Right, thats the DOT issue swen up. Any more 'likes' for ATE blue, and also how much will I need for a full and bleed and fill?
Rallye-R
Nurburgring article
Posted 20th Sep 2012 at 14:07
RBF 660, brilliant stuff and gets to silly temperatures without boiling. I think you need about a litre, maybe more if you still have ABS.
Posted 20th Sep 2012 at 17:00
iplay
All the boiling points are listed in post#11
SRF ftw. It has the highest boiling point but that is only part of the story. It feels great too. Although it will absorb moisture over time and needs changing every 18 months. Worth it if you want the very best braking feel.
Posted 20th Sep 2012 at 20:43
Whilst the boiling points are a good guide, I would base a choice on peoples experience rather than figures. They're an okay guide but a decent fluid will out-perform a cheaper one any day; think of them as being like fuel consumption figures for cars - you can get a rough idea which car will do better, but different manufacturers have very different ways of coming up with these figures.
Posted 21st Sep 2012 at 07:01
I used AP551? fluid, never led me down, good consistant pedal feel. Reasonably priced and comes in sensible sized bottles so you don't waste much if you don't use all of a container full.
Posted 21st Sep 2012 at 12:24
AP's fluid tends to give a firmer/more consistant pedal than even SRF, even if it doesn't do the same temperatures.
RBF600/660 is good for the money though.
Posted 21st Sep 2012 at 19:20
