I can imagine it's a fiddly old process. What sort of route does it take?
Thanks
| Author | Subject: Bonnet Cable |
darrengti
Regular Location: Exeter Registered: 23 Jan 2007 Posts: 372 Status: Offline |
Mine needs replacing. Anyone had any experience of fitting one? No guide, barely a mention of it online. I can imagine it's a fiddly old process. What sort of route does it take? Thanks |
rikky
it goes through a grommet in the bulkhead behind the dash insulation from memory close to the side of the chassis. where has it broke? can you see anywhere? i would try and feed it through by the same sort of process as a clutch cable by attaching old one to new one and pulling it through the bulkhead, but depends where it's brokei've only ever done it on stripped out cars, which helps ![]() ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
darrengti
It's gone on the end near the bonnet catch so plenty to attach too. Which way would you thread it, inside to out or vice versa? |
rikky
>edit - forget that bit cos the release catch end is just a profiled end so should pull through easily! ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
rikky wrote: depends on the cable i guess, is it like a universal one where you physically attach the end bit which sits in the throttle body / pull handle? cos it's easier to pull a single wire through the hole rather than the cable with the nib on the end the one i had on my s16 had the handle end moulded into the cable but the TB end had a cylinder you screwed on to fit in the TB so i pulled it through from inside to outside since when has the BONNET PULL CABLE, operated the THROTTLE BODY? Pretty certain it is covered in the Haynes manual, you'll need to buy a complete unit from Peugeot for about £35. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rikky
maybe i should read what i write, editedi meant to the bonnet catch ![]() then again would be pretty cool having bonnet pull catch as accelerator ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
