Author Subject: Revs dropping when heated rear screen is turned on
ballardpaul
Anyone ever got this and is it quite normal? I can understand it dropping abit but by 200rpm? And the AFR increases but no other electrical item makes this happen.
Can anybody shed any light on this please?
Thanks
Nissan 350Z (300 BHP)
Posted 25th Sep 2012 at 22:16
It's a big load, and if your ICV is'nt in good nick it doesn't handle that sort of thing very well.
Posted 25th Sep 2012 at 22:46
clen666
Don't think he has an ICV Wink
Team 'unintentional rat look'
Posted 25th Sep 2012 at 22:52
ballardpaul
Graeme's right no ICV Dunno
Posted 25th Sep 2012 at 22:55
Well with nothing to lift the throttle vs the increased load from the alternator it's hardly surprising the revs drop. Can you raise the idle speed a little to compensate? If it drops 200 rpm that's right on the verge of stalling and would explain your nasty AFR reading.
Posted 25th Sep 2012 at 23:00
ballardpaul
Wouldn't really want to raise idle anymore as it sits around 1100 iirc. I'll keep an eye on it, it's not that close to stalling just something I noticed today and wondered if anyone had any ideas.
Didn't realise the rear heated screen increased the load by that much, no more than say the blower.
Posted 25th Sep 2012 at 23:31
It's a lot more, only a few amps for a motor, but more like 20+ amps for a heated screen, that's probably why it set to idle at 1100 and not the usual 950 rpm then. Just something you're going to have to put up with then I guess.
Posted 26th Sep 2012 at 07:59
Sounds like you've bought a lemon ballbag Whistle
Posted 26th Sep 2012 at 13:50
Paul,
Having the same running gear setup as you, I would suspect mine also does this. Yes
However, seeing as I have never driven it in the winter or anytime after September during the year, I've never had need to use the heated screen. Doh
But yeah, as Jim says, the heated screen is a huge electrical load in comparison to other items on the car. Yes
Posted 26th Sep 2012 at 20:24
swiftyboi006
However, seeing as I have never ever driven it simply because the car does not exist, I've never had need to use the heated screen.
EFAThumbs up
Black p3 Love
Posted 26th Sep 2012 at 20:32
LOL
I will prove it exists one day...Laugh
Posted 26th Sep 2012 at 20:34
ballardpaul
Fair enough then just have to get use it.
Posted 27th Sep 2012 at 16:03
The next time I do actually drive mine, I'll test this for you and post up the results. Pretty sure it'll be the same though.
Posted 27th Sep 2012 at 16:41
^^^ Won't happen... Dry
Posted 28th Sep 2012 at 08:00
why no ICV?
Posted 28th Sep 2012 at 09:50
LOL
Yes it will...
Posted 30th Sep 2012 at 11:55
why no ICV?
The ECU doesn't use it for the idle speed. The idle speed on mine and Paul's car (Buzz's too I suspect) is controlled by a hole drilled in the butterfly. Yes
No ICV cleaning problems for us. Cool
Posted 30th Sep 2012 at 11:57
