Author Subject: 1st blast in the new 6
swiftyboi006
As some of you may now i used to own a cherry p1, handled very well indeed lowered with strut brace ect. Just got the blaze through the mot what made me happy so i thought id give it a test with an mg zs that a couple chavs wer driving, got to a nice road and goodbye runs sweet as a nut. The engine runs better than the p1 (rebuild 20k ago) but the handling isa bit rear end happy. Would lowering with just front springs and strut brace help this? Dnt want to spend out as its been cheap so far
Black p3 Love
Posted 29th Sep 2012 at 07:42
aaron6
No. It's probably the rear beam mounts getting tired. Smile
Posted 29th Sep 2012 at 08:06
playboyb
Sounds like the beam mounts, get some solid mounts on there unless you like passive rear steer, in that case new pug mounts will do the trick Smile
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 29th Sep 2012 at 18:54
aaron6
Passive mounts ftw!
Posted 29th Sep 2012 at 19:03
swiftyboi006
Rear beam mounts are new Dunno
Black p3 Love
Posted 30th Sep 2012 at 12:21
daver6
balljoints / front suspension?
Wishbone Polybushes available
Posted 30th Sep 2012 at 12:51
swiftyboi006
Just changed the p bushes everything else is fine just passed mot. Wen i can be assed ill get the beam off to lower it and have a proper look at the mounts but im pretty sure they wer new
Black p3 Love
Posted 30th Sep 2012 at 12:56
aaron6
Ovalised hub on the front?
Posted 30th Sep 2012 at 15:12
ryangti6
Id be looking at Tyres
Do you have better on the front? Pressure right in them etc?
Either that or seeing as you said just passed mot I'd say its more likely tired front suspension, they will only check for play and rebound on the test usually so won't show up if they've gone a bit soft.
Ryan
Posted 30th Sep 2012 at 15:41
swiftyboi006
Its the rear of the car tho?
Black p3 Love
Posted 30th Sep 2012 at 16:15
aaron6
I know that front suspension issues can cause the tail to feel loose. Maybe your new rear bushes are too soft. Were they pug one's? Probably front suspension or p**s poor tires. Smile
Posted 30th Sep 2012 at 16:33
swiftyboi006
Will have another look once i get time there all good tyres on there apart from the frots are a bit worn. Mite get some new mounts for the rear anyway if the beams coming off
Black p3 Love
Posted 30th Sep 2012 at 16:36
aaron6
Get the pug ones. If you wanna save cash get the solids from miles. I don't know why but the rubbers are dear. Worth it though. Smile
Posted 30th Sep 2012 at 16:50
ryangti6
Above you said the rear mounts are already new...
I know you said the rear is the problem but if the front is tired and the back is all tip top with new mounts etc you will have lost the balance in the car and if the back is stiffer/tighter it will make it want to lose grip before the front.
What I meant with the tyres is more brand/quality than actual wear (unless you have 4 matching tyres). If you've got something like Michelin on the front and Nankang's on the back then your car will behave like you are describing, if they are all the same and the front are significantly more worn then it could be worth swapping them around and see if it's better.
Ryan
Posted 30th Sep 2012 at 17:23
swiftyboi006
Cheers for the help
Black p3 Love
Posted 30th Sep 2012 at 17:29
