Author Subject: oil sump replacement alternatives ?
edhunter
Hello
For second time I broke my original aluminum oil sump. This time I am thinking to replace it with iron oil sump.
My question is - from what other peugeot engines the oil sump is iron and is compatible with gti-6?
Are there any serious drawbacks/disadvantages if I move to iron oil sump?
Thanks in advance
Posted 3rd Oct 2012 at 08:49
jonnie205
best with the alloy sump as it braces to the gearbox etc and is baffled. I would raise the front of car or fit a sump guardThumbs up
Posted 3rd Oct 2012 at 08:56
^^^Exactly this. Yes
How have you managed to break two sumps? Dunno
Posted 3rd Oct 2012 at 09:05
miles
The tin sump from the S16, Phase 1 8v XSI are all baffled and will fit, you will loose a couple of bolt holes for the box but it's no less than allot of other models have.
I run tin sumps on most Rally car's for that very reason, even with guards, Belt and braces I know
www.pugracing.com
Posted 3rd Oct 2012 at 22:45
I run a baffled tin sump on my RS engine, full non a/c S16 aux setup too so a lot lighter.
Posted 3rd Oct 2012 at 23:07
clen666
How much lighter is the S16 sump then?
Any other drawbacks other than fewer bolt holes for gearbox?
Team 'unintentional rat look'
Posted 3rd Oct 2012 at 23:25
Dunno, never weighed it and i sold it to an irish guy for €30 and re-used the cars original sump LOL
Posted 3rd Oct 2012 at 23:34
edhunter
I bought used non aluminum sump (from 2.0 8v i think). It looks very thin and light. It has no baffle, but we will work some for it.
I have been told that it may not brake (like the original one) and will survive slight hit, but there is a risk to smash the oil pump.
The mechanic that is working on my car suggested that since I am using this car only for trackdays and I am changing the oil in time, it is good to cut the oil "sucker" and put soft tube with same length instead. This way the oil pump will survive if the sump get another hit Smile I still have not confirmed if I am ok with this operation.
What do you thing?
Posted 8th Oct 2012 at 19:31
Seems logical, but two things come to mind as problems, some pipes get soft when immersed in oil, even more so when the oil is hot so the risk of it sucking flat under vacuum is something to think about, the other is the fact that if the pipe develops s leak you'll loose oil suction. Either will result in a dead engine so I'd think carefully about a heavy duty sump guard instead of pickup mods if I were you.
Posted 9th Oct 2012 at 00:10
Is the XU9 the same sump bolt pettern/layout as the XU10?
Posted 9th Oct 2012 at 09:32
edhunter
Daveboy, thanks for answer.
The pipe will be resistant to oil and temperature. Also there will be some spring around it.
You are right about sump guard - it would be best solution. We will fit one, but this will happen in the winter - when there will be plenty of time available for invetntions and works Smile
About XU9 and XU10 sump bolt patterns - sorry I don't know.
Posted 9th Oct 2012 at 10:55
yes, all XU are the same.
why not run the car higher, or on stiffer springs?
Posted 9th Oct 2012 at 12:25
edhunter
The car is not too low (maybe about -30mm from stock height). It is on Eibach springs with Bilstein B8 shocks.
I would like to make it stiffer, by using coilovers where I can select springs with different rate. But the rules in our local amateur championship limits the number of modifications allowed for street cars - and if I go for better suspension I will skip this limit.
That is the reason to seek for alternative solutions Smile
However the usual "sump breaker" is a track where even higher and much stiffer cars have broken their sumps Smile Also the other tracks we use are not so smooth and in good conditions.
Here are a few photos:
http://store.picbg.net/pubpic/F9/64/c275a2699c89f964.jpg
http://store.picbg.net/pubpic/2B/48/47ec7a9690f02b48.jpg
Posted 9th Oct 2012 at 17:18
sounds like you just need to slow down!
Posted 9th Oct 2012 at 17:41
