Author Subject: Management light on at 5500rpm
dan86
This is on my 1.8 16v XS xu7jp4.
I have a hesitance after 5500rpm at which point the engine managment light comes on and then goes out when I drop the revs for the next gear.
I've changed the plugs, coil pack, lambda sensor, MAP sensor and the TPS to no avail.
There is a small black cube looking sensor bolted to the end of the exhaust cam carrier. It has a black wire coming from it that goes to the plug for the coil pack. Anyone know what this is?
I'm determined to get this sorted as other than this little niggle its a spirited little motor.
Thanks in advance.
Posted 4th Oct 2012 at 22:19
the little thing you describe is just a capacitor (IIRC) to prevent RF noise.
is it modified and have you had the codes checked?
Posted 4th Oct 2012 at 22:42
dan86
Thanks, I wondered what it was.
The only modification is a gti6 exhaust manifold, cat, centre section. Everything else is standard inc airbox/air filter.
This problem was there before the exhaust components were changed and is still the same.
I was wondering if it could be an ecu fault with the sl96.
I had the codes checked and it said lambda sensor fault which I changed. It made a difference but still this hesitance when approaching redline.
Posted 4th Oct 2012 at 22:53
It might be running lean with the different inlet and the hesitance is the ecu trying to work out what the hell is going on.
Posted 4th Oct 2012 at 22:58
dan86
It's the standard plastic inlet. Only the exhaust mani has been changed.
Posted 4th Oct 2012 at 23:02
dan86
Should I bin the lot and go down the ITB/DTA route?
Posted 5th Oct 2012 at 08:33
Yeah, instead of paying £30 to have the codes checked, spend £1500 on throttlebodies, why the feck not LOL
Posted 5th Oct 2012 at 08:41
dan86
I feel this engine has great potential with better management and bodies. I love how effortlessly it revs and how light it makes the front end. It's like driving a 205 gti.
Needs more power though.
Posted 5th Oct 2012 at 09:00
yup, Sandy Brown did essentially that with a 309 Goodwood.
Posted 5th Oct 2012 at 09:32
dan86
That's interesting to know. It's starting to become quite popular with the 205/309 guys I've noticed.
I would be really happy with 150hp which I don't think is too far out of the way. It has a lot of torque as standard and really pulls from 3000rpm. Surprising for an over square engine.
You have an xu7 yourself don't you Mei?
Posted 5th Oct 2012 at 09:43
kinda, I have one in millions of bits, sat in my bedroom with an XU5 crank in it and an XU10J4R head on the top.
Posted 5th Oct 2012 at 09:45
dan86
Ooh nice Smile what are your plans for it. 205?
Posted 5th Oct 2012 at 11:02
dan86
I plugged the diagnostic machine into my car again to see if any more faults show up and low and behold;
Posted 5th Oct 2012 at 22:54
There's your answer then. Wink
Posted 6th Oct 2012 at 07:21
dan86
At least I know where to look now. Now to figure out if its a bad injector or a break on the loom.
Posted 6th Oct 2012 at 10:08
It's probably a dodgy injector to be honest out of the two I would have thought. Yes
Posted 6th Oct 2012 at 18:52
dan86
That would be nice as its only a case of swapping for a new one. I'm not a fan of repairing wiring looms tbh.
Posted 6th Oct 2012 at 19:52
marc l
Or you could swap the injectors around and see if the fault code changes?
2001 BLACK Phase 3 XS - Sold April 2010
1999 WHITE Phase 3 GTi6 Big grin
1991 Peugeot 205 1.6 GTi - Track Car
Posted 6th Oct 2012 at 20:00
This would be the best option, swap 1+4 with 2+3, clear the ECU and then see what code it throws. Yes
Posted 6th Oct 2012 at 21:30
dan86
That's a bloody good idea. I'll do that.
Thanks for all the info guys. Thumbs up
Posted 6th Oct 2012 at 23:51
