displaying posts 526 to 550 of 1018
Pages (41): first .. 21 [22] 23 .. last
Author Subject: My 306 Dimma project, Mainly photos
pete_rallye
Post #526
That is looking really really good! Am looking forward to it been finished...
Lap of the 'ring
Posted 23rd Oct 2014 at 16:30
pugheaven
Post #527
Thanks, I can't wait either! Shame it's the wrong time of the year lol
Well I took the dummy shock out and it has come down to the perfect height Smile
The fronts are on the bump stops so they will need to be cut down.
Posted 23rd Oct 2014 at 18:57
Post #528
you do realise if its on the stops then you need shorter dampers or a higher ride height, not to cut the stops right...
cutting the stops just leads to the damper twatting itself to bits internally.
Posted 23rd Oct 2014 at 19:10
Post #529
Does the dimma just use normal standard topmounts but the chassis cut/drilled further out to accomodate the wide track?
Posted 23rd Oct 2014 at 19:15
pugheaven
Post #530
Hmmm true, the stops are like 3" deep, can they not be shortened at all?
Posted 23rd Oct 2014 at 19:19
Post #531
you'd be surprised how far they squish down with a decent bump.
Posted 23rd Oct 2014 at 19:27
pugheaven
Post #532
It uses standard top mounts but sit in some McPherson adaptors that are bolted further outboard
Posted 23rd Oct 2014 at 19:33
pugheaven
Post #533
They are the bump stops that come with the gaz golds, they are pretty tough rubber, I might raise the front 10mm and cut 30mm off the stops, if it bottoms out when driving I'll get stiffer springs
Posted 23rd Oct 2014 at 19:48
Post #534
Do the McPherson adaptors basically make the topmount sit lower than they normally would then?
Posted 23rd Oct 2014 at 19:53
Post #535
yep but not by much, its just an ally plate.
Post #536
I was just thinking whether they would work with aftermarket topmounts, some essentially lower the car about an inch but don't need the ride height changing on the damper as the damper mounts higher up.
Posted 23rd Oct 2014 at 20:31
allanallen
Post #537
Ollie, speak to gaz about the stops. I know with the rears they have internal stops and the external are apparently just to act as extra spring rate as they reach the end of their travel.
Facebook
Posted 23rd Oct 2014 at 20:42
pugheaven
Post #538
Cheers Allan I'll give them a ring tomorrow!
I tried compbrake, d2 and baker bm top mounts but due to them.needing to be outboard the topmounts didn't sit correctly against the chassis due to the profile, that's why I went down the negative camber hub option instead
Posted 24th Oct 2014 at 10:10
pugheaven
Post #539
Problem solved, Just phoned gaz and they have said that I can remove 2" of the external bump stop with out the piston bottoming out Smile
I'll be raising the front by about 10mm so fingers crossed I will never use the full amount of travel before bottoming out
Posted 24th Oct 2014 at 10:08
Post #540
Havnt checked this for a few months looks like you've made some really good progress mate looks stunning!
Posted 31st Oct 2014 at 14:10
pugheaven
Post #541
Thanks mate, not really done a lot apart from get the beam and wheels on Sad
Itching to get on with it but currently occupied with doing the house up Thumbs down
Posted 1st Nov 2014 at 09:33
Post #542
Wouldn't say there's a big rush now as it's almost winter. I've stopped doing stuff to mine till next year really. See if I can finally bother to save up for a diff and maybe get it caged.
Posted 1st Nov 2014 at 09:50
superchargedblack1997gti6
Post #543
Hello mat did you want a bolt in towing eye off a phase one? As unfortunately I have one now?
Posted 1st Nov 2014 at 10:34
pugheaven
Post #544
Yes please bud, as long as it's not rusted beyond repair Thumbs up
Posted 1st Nov 2014 at 11:19
pugheaven
Post #545
The house is now finished and up for sale so I might actually get to work on the car Smile only thing is I'm still working away so will only be able to work on it on Saturdays Sad
I'm still not sure if I'm going to use pro alloy as I'm trying to save as much money as I can for a bigger deposit, as its crap weather now I'm in no rush to finish it but I still want it finished by February!
As today is very rare and the sun is out I pushed it out side for a few pics
Posted 9th Nov 2014 at 11:48
RetroPug
Post #546
Absolutely love the colour in the sun, really can't wait to see this finished.
Posted 9th Nov 2014 at 12:17
pugheaven
Post #547
It's a really weird paint, it's purple in the dark then goes to the blue above but when the sun really hits it it changes again and sparkles
For a camara phone the pics are good but don't do it any justice at all
Posted 9th Nov 2014 at 15:17
RetroPug
Post #548
Best get it finishedand bring it to some shows and meets then so we can see it in the metal! Big grin
Posted 9th Nov 2014 at 15:30
pugheaven
Post #549
That's the idea buddy, I just cant wait to drive it! its been soooo long since iv had that supercharged thrill
Posted 9th Nov 2014 at 15:47
pete_rallye
Post #550
That looks so awesome. f**k shows and meets, I would like to try and break the fwd lap record around the Nurburgring in it if that is ok? You should really box in all the fuel stuff too, make it eligible for racing
Lap of the 'ring
Posted 9th Nov 2014 at 22:10
