Author Subject: Seatbelt jammed
davewagon
Okay, not life threatening...
But my seatbelt has totally jammed, and can't be pulled out to operate?
The last thing I did was to move the seat forward and back to load something in the back seat and now it's stuck!
I've tried moving the seat back and forward again, pulling gently and yanking on the f**ker!!
What can i do, i'm stuck out a friends house, with no tools and no (legal) way of getting home.
Also need to go to work tomorrow morning
Any ideas??
Regards
Dave
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 10th Oct 2012 at 19:56
rich306
tried feeding the belt back into the roller at all? feed it in then pull out gently?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 10th Oct 2012 at 20:07
davewagon
Yeah sort of...
The seatbelt was fully retracted as it was, so not really anything to feed back in?
I tried lowering the top bracket down an inch or two to allow me to feed more back in, but it's just gobbled it up and won't give any back...
i'm kinda stranded (but not really)
Posted 10th Oct 2012 at 20:10
rich306
Hmmmm
Right, are you in any way able to take the cover off?
- Top Tip!!!
Posted 10th Oct 2012 at 20:15
rich306
If so, give the seatbelt unit a whack, should knock the release bearing into place so you can at least drive safely.
Then as soon as you can get a new seatbelt to replace that one.
- Top Tip!!!
Posted 10th Oct 2012 at 20:27
davewagon
Thanks for your help Rich
Will give it a go!!
Posted 10th Oct 2012 at 20:43
davewagon
Will give it a go!!
Posted 10th Oct 2012 at 21:29
Not got a Bungee rope in the boot? Stretch across chest in the usual fashion.
Or, if your festively artistic perhaps make a cable tie chain.
Perhaps lay the drivers seat right back, sit up on the seat back and use the headrest to support your lower back as your stretch the rear seatbelt around your middle.
Sorry I can't help. Although count yourself lucky that you aren't stuck in the seat with the belt jammed in the buckle. "Can someone help me, I'm restrained in my seat and my waters have broken but I can't reach my Gingsters".
  • Posted 10th Oct 2012 at 21:34
    davewagon
    Very good
    It seems to have sorted itself on the journey back home, maybe was the way I parked the car??
    Probably just being French ...
    Dave
    Posted 10th Oct 2012 at 21:42
    It was probably the vibration and going over bumps which unseized the stuck bearing and allowed the seatbelt to operate properly again. Yes
    Posted 11th Oct 2012 at 06:22
    Chris28190
    I think this, I found it happens every so often if you park on the p**s.
    Cherry Rallye '99 - Sold
    Posted 11th Oct 2012 at 07:16
    davewagon
    Well the last thing I dad was bump it up a curb onto a grassy hilly area directly outside a friends house so I could load an office chair into it (I swear the 306 is the closest thing to a tardis!)
    So it bumped over a rut or two before coming to rest at a funny side on angle on the side of a hill
    Maybe enough to stick the belt bearing? And then it righted itself after driving off and levelling etc etc ...
    Posted 11th Oct 2012 at 08:40
