Author Subject: Vibration
simbob
Hi guys hope someone can help as when driving normally have vibration from approximately 20mph through to the low hundreds, was thinking it could be a wheel bearing or hub but have been in a garge now for a short time and no idea .
HELP
Happy to be back in a 306 again!
Posted 11th Oct 2012 at 19:49
standard Cyclones? get them balanced Thumbs up
or, does the gearstick wobble? could be a driveshaft.
Posted 11th Oct 2012 at 19:57
simbob
No oz 17" superleggras with 20mm spacers . Bein spot on until yesterday
Posted 11th Oct 2012 at 19:59
check the wheel bolts, hit any potholes? probably worth getting them off and checked for buckles etc.
Posted 11th Oct 2012 at 20:02
simbob
Had them off most of the day had them balanced at 2 different places and were fine. Haven't hit any pot holes, but do rabbits count ???
Posted 11th Oct 2012 at 20:12
Teshboi1988
check the wishbone bushes....
i had same problem some mad vibrations through steering... my bushes were f**ked. replaced with polys and now its rolling sweet
phase 3 Hatchback V reg 5Door GTi6
Posted 12th Oct 2012 at 07:32
swiftyboi006
Bushes dont usually cause vibrations tho but worth a check, get it up in the air n give it a once over
Black p3 Love
Posted 13th Oct 2012 at 09:40
Driveshaft / wishbone / top mount / bearing / gearbox parting from engine / scrap it and be done
Posted 14th Oct 2012 at 21:22
simbob
Not a chance I love it mr B
Posted 14th Oct 2012 at 21:24
It is therefore going to rape you Wink
Posted 14th Oct 2012 at 21:27
simbob
Oh well s**t happeneds . What else would I replace it with dude ??? It's not worth much so may aswell fix it and run it in to the ground .
Posted 14th Oct 2012 at 21:34
So you suddenly developed a wheel wobble so decided to take the car up to 100 to see if it stopped?
Posted 14th Oct 2012 at 22:13
simbob
Stupid but yeah !!!!!
Posted 14th Oct 2012 at 22:22
Could be your brain bottoming out perhaps.
  • Posted 14th Oct 2012 at 22:32
    LOL^
    In all seriousness whenever i've had an issue like this and its been rotational i.e wheels out of balance or driveshafts, its always been vibrating at a fixed speed or more of a smaller range of +-10mph or so. The fact you are saying that it does it from 20-90+ makes me think its something a more fundamental like a engine mount being royally shafted or some bush/worn out rubber related issue.
    When i first had my car I was chasing loads of bits about trying to find a cause. In the end for me it was a bit of everything :s
    -I replaced the lower engine mount (have you checked this btw?)
    -a driveshaft
    -Noticed my dash wasnt properly secured on the passenger footwell (This was making all of the above and below seem worse than it was)
    -Got my wheels balanced x number of times before finding someone that actually did it and them tell me they were over balanced 10x too much on the wrong side.
    (FunFact, I lost 500-600g of rotational mass across all 4 wheels that day... That how bad ALL of them were)
    -a warped brake disc
    After each of those things being replaced there was a marked improvement until they were finally all done and it was gone, so each one was part of the cause.
    Posted 14th Oct 2012 at 22:44
