Author Subject: Track car weight
demondriverdan
Has anyone had their track car weighed? Trying to get an idea of what weights people have achieved Smile
Rallye Race Car
Posted 21st Oct 2012 at 14:39
I had mine down to around 1020kg before i had the roll cage fitted. That was stripped, most un-necessary brackets removed, no spare wheel etc. Standard seats & glass windows, very little fuel from memory.
Posted 21st Oct 2012 at 14:57
swiftyboi006
Can get these around 950kg with some light buckets, all sound deadening removed poly windows etc
Black p3 Love
Posted 21st Oct 2012 at 15:38
306 Rxs
Stage 1 @ 970kg - no sound deadning, 2 itr's recaro, electric sunroof out, oem 15'' wheels...
Stage 2 @ 860kg - 1 carbon bucket seat, 15'' TD Pro race 1, half dashboard, polycarbonate x 4, striped bonnet, alloy rad, single wiper kit, lightweight brake kit, slim fan, simplified engine and dashboard loom, ...
Both without rollbar.
What is a hybrid?
Honda engine...Ford brakes...Peugeot chassis...Vauxhall steering...
Posted 21st Oct 2012 at 16:19
eddiebeano
1040 kg with full cage. 2 buckets, poly front windows, all plastics removed except dash, lighter wheels brakes etc
team: Stealth Ninja
Posted 21st Oct 2012 at 16:21
Maxi's are 950 kg with proper cages and 18" wheels iron block engines and heavier sequential boxes, steel panels.
Posted 21st Oct 2012 at 16:33
pete_rallye
Most of the weight loss on a maxi is at the rear beam though, which isn't practical for a track day car! I'd be surprised if a 306 has got down to 860kg still driveable too. My old 306 was about 1020kg with 1 bucket seat and nowt in it. Perspex windows, doors and interior were chopped out as far as you could go without thinking alloy boot floor and stuff like that. Even if the panels were changed to fibreglass I would think there would be maybe 30kg to save at the most.
Lap of the 'ring
Posted 21st Oct 2012 at 17:13
demondriverdan
Thanks for the info guys. I'm eventually looking to start racing in Trackday Trophy and they separate their classes by power to weight ratio. The classes are split thus:
Class B 151 - 175 bhp/ton
Class C 126 - 150 bhp/ton
Class D 101 - 125 bhp/ton
Class E up to 100 bhp/ton
There is a Rallye that raced before with a weight of 1116.5kg and ATW power of 130.2bhp. That puts them at a P/W of 116.6bhp/t, squarely in class D.
So, based on your info and that I don't do any engine work (bar a good service), if I can get the weight to around 1040kg I should be at the max amount for that class.
Rallye Race Car
Posted 21st Oct 2012 at 18:34
306 Rxs
Maxi examples are a perfect waste of time, because they even use original door cards, electric windows, etc...
There's a lot of weight to be saved on little details such as a simple bracket that holds engine acessories...7kg'ish of pure waste, wich can be turned into a few grams with a s16 simple bracket for the alternator.
My car isn´t for road use, altought it can go to trackdays driving it.
Power steering off - 10kgs less
Front hi spec brakes - 10kgs less
Rear brake lightweight treatment - 4kgs less (handbrake cables and simplified calipers)
Fully chopped doors and boot - 25kg less
Smaller engine starter - 2kg less
Smaller alternator - 3kg less
Smaller battery - 10kgs less
Abs ph1 out - 8kgs out
Gti6 bracket
After...(s16 bracket lightweight version)
What is a hybrid?
Posted 22nd Oct 2012 at 03:27
eddy_gti6
Had my gti6 down to around 900kg i will hunt out my photo on the weigh bridge
Posted 25th Oct 2012 at 02:32
