[edit] Just to clarify:
It's the hollow tube linkage that goes through the spring etc as seen here.
| Author | Subject: rear bias compensator linkage |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
The linkage between the bias adjuster and the trailing arm on mine has gone, so if anyone's got one from a car they're breaking, that would be great. [edit] Just to clarify: It's the hollow tube linkage that goes through the spring etc as seen here. ![]() ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
Got one of those knocking about I think. Will check.________________________________________ ![]() |
darkstar753
Regular Location: Enfield Registered: 12 May 2011 Posts: 241 Status: Offline |
Pretty sure I have one lying on the garage floor, but its back at home and I'm not back for 2 weeks now.If you still need one then I'll have a search and grab some pics ________________________________________ Darkstar |
24seven
Cheers folks. If you can post pics/price we'll sort something out. ![]() ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
Found it out but it's in s**te condition. Can't you buy them from Pug cheap enough?________________________________________ ![]() |
no, its part of the valve assembly.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
24seven
ahh bugger. Not to worry dan, I'll sort one from somewhere. Pretty sure it's an MOT fail if the compensator is there but not working, otherwise I'd just leave it for now. ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
not so much that, bit it'll fail because the rear brakes are doing feck all I might have one.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Gotta love the 172 Cup on that issue. Many garages want to fail it.________________________________________ ![]() |
24seven
Anyone else have one, per chance?________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
I'll get a pic of that one I have later Guy.I dismissed it due to the plastic sheath being a bit s**tty, but see what you think. ________________________________________ ![]() |
24seven
Ok dan, cheers.________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
darkstar753
Got the old man to take some piccies:Lemme know ![]() ![]() ________________________________________ Darkstar |
24seven
That's the jobby. Looks ok to me. I don't need the compensator itself, just the linkage assembly. How much do you want for it posted mate?________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
