Author Subject: Hybrid anti roll bar handling.
eddiebeano
Hi, so I fitted a hybrid arb tonight, splines lined up with end plates fine. The rear of the car seems so much stiffer over bumps just for the arb, plus the handling could be described as twitchy, as in if you lift off on a corner, it's going to have you! However, if I put the power down through the corner it is excellent. My current set up is kw v2 up front, 21mm tb and hybrid arb out back, solid mounts and standard old rear dampers. Could the standard dampers cause a problem? I should say that upon removing the old arb it was infact smaller than an original gti6 arb. The change is such a shock. Anyone have any advice or similar experience?
Ed
team: Stealth Ninja
Posted 24th Oct 2012 at 22:21
That's pretty normal for uprating a rear anti-roll bar, it reduces the amount of potential rear grip available in exchange for less overall body roll
Posted 24th Oct 2012 at 22:28
standard dampers with that lot is a fail recipe waiting to be baked.
however I wouldn't call it particularly stiff at all, though removing the rubber from the beam mounts means that when you get to the edge that's it, its sliding no matter what, at least the o.e gives you some warning Wink
Posted 24th Oct 2012 at 22:33
miles
The ARB has nothing to do with the stiffness on the back, it does as it say and helps to control roll,
I run 30's in all of mine as I've never seen a huge/small gain with the Hybrid one and they are all planted as can be, mind the rear dampers are Group N one's
But the main difference I think you will have is going from a base model ARB
www.pugracing.com
Posted 24th Oct 2012 at 22:37
JWP EFi
Turbo Legend!
mounts - i agree
Posted 24th Oct 2012 at 22:38
eddiebeano
I forgot to add, the rear seems very 'bouncy' compared to before. It feels really planted when putting the power down, its just when I lift off, it wants to kill me!
team: Stealth Ninja
Posted 24th Oct 2012 at 22:46
JWP EFi
Turbo Legend!
dont lift off lol
Posted 24th Oct 2012 at 22:48
sounds like yer dampers are fooked.
eddiebeano
Well the next purchase was going to be group n 205 dampers Yes
team: Stealth Ninja
Posted 24th Oct 2012 at 22:50
24seven
As phillipm said, that's to be expected. You've increased the roll stiffness of the car, which means reduced body roll but more weight transfer to the outside wheel and thus reduced maximum lateral traction. When you put the power back down, the weight balance of the whole car shifts towards the rear and suddenly it grips again, so in effect you're balancing between having the lift-off oversteer to point the car around the corner and having traction to stop you going backwards into a hedge.
Posted 24th Oct 2012 at 22:51
eddiebeano
Just for comparison, here is a pic of hybrid arb against my old arb in the middle and a standard gti6 arb on the right
team: Stealth Ninja
Posted 24th Oct 2012 at 22:58
woody.
Have you measured them?
Posted 25th Oct 2012 at 01:29
JWP EFi
Turbo Legend!
19mm, 24mm, hybrid-28mm
Posted 25th Oct 2012 at 08:36
mark.evs
How are your rear beam bearings? They can cause the same problem.
My GTi6 track project
White Rallye project
Posted 25th Oct 2012 at 10:09
eddiebeano
I think they're ok, no camber issues and beam has been part recently.
team: Stealth Ninja
Posted 25th Oct 2012 at 21:37
