97 1.6 xs gti6 conversion
scrapped99 black rallye ( low miles and immaculate
new owner of a 2001 diablo red hdi mile muncher
swapped99 red rallye turbo sold then died
00 moonstone 1.9d (slow)
displaying posts 1 to 25 of 44
| Author | Subject: cleaning inlet manifold sensors |
boost
Regular Location: peterlee Registered: 22 Jun 2012 Posts: 245 Status: Offline |
sorry for all the threads lol but whats best to use to clean all the sensors on the inlet mani or would it damage them ? just wana clean them to see if there clogged up ________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
gti6girl
Seasoned Pro Location: Dartford Registered: 19 Feb 2007 Posts: 2,692 Status: Offline |
Brake cleaner |
bas_306gti
Regular Location: Eindhoven Registered: 06 Sep 2012 Posts: 108 Status: Offline |
The only items who needs cleaning is the ICV (perhaps MAP and Air sensor) and the throttle body/manifold itselfThe way to clean them is to disassemble the manifold and throttle body and clean them with brake/carb cleaner |
boost
u think with a good clean they may inprove fuel xonsumption cause it seems to be real bad on fuel ![]() ________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
stan_306gti6
boost wrote: u think with a good clean they may inprove fuel xonsumption cause it seems to be real bad on fuel ![]() Not really, you can't really "clean" a MAP sensor to be honest. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
boost
i thought all the sensors got clogged after time ________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
stan_306gti6
The sensors don't really get "clogged" they're not sink plug holes. ![]() The only sensor which really gets anywhere near "clogged" is the lambda sensor as it can get quite sooted up depending on your AFR's. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Tbh I'm not sure any of them respond to cleaning either. They are usually just fecked________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
boost
haha didnt really know that i just thought they gpt a bit clogged over time n needed a bit clean nevermind lol ![]() ________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
stan_306gti6
No worries, if it ain't broke don't fix it. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stan_306gti6 wrote: No worries, if it ain't broke ![]() EFA ________________________________________ ![]() |
stan_306gti6
Well yes, you could look at it that way. Enjoy the rest you have now as you'll soon have all your spare time taken up with repairs etc. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
boost
lol touch wood its fine up till now only really had the plug issue the other day and the fact its a thirst motor ![]() ________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
stan_306gti6
boost wrote: and the fact its a thirst motor ![]() They shouldn't be *that* thirsty. You should see around 300-325 miles per tank with mixed driving. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
boost
ill be lucky if ill see 200-250 mixed driving mate its unreal there has to be sumit wrong sumwhere ![]() ________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
Normally lambda sensor or coolant temperature sensor mate. Try and get a known good one and try it, if not buy a new one |
swiftyboi006
Lambda is themost common for this or driving at 5k+rpm like some people do ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
boost
cheers lads al give it a shot n another thing if the thermostat is stuck open (think it may well be cause when driving it sits at 70degrees ) is there anyway of unsticking it or just buy a new one ?________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
stan_306gti6
If your thermostat is stuck open (which it sounds like it is) then this will most likely be the cause of the poor fuel economy. ![]() The engine will be running cold and therefore it will be running rich to compensate. Fit a new one, I'm sure you'll see an improvement. The stat on these are set to open at 83C so the reading on the instrument panel should be around this figure when travelling after the warm up phase. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
boost
ok cheers mate ill try pick one up today ![]() ________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
stan_306gti6
boost wrote: ok cheers mate ill try pick one up today ![]() From experience I would suggest buying a Pug one. ![]() I bought a brand new one from a factors a few years back for £6 and it got stuck open VERY quickly and made my engine run at 70C. I went to Pug for a replacement and felt a bit ripped off at £18, however it's run faultlessly and is still being used in my current engine a few years on. ![]() Get what you pay for in my opinion. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
boost
pug parts are always better like a think al go today n pick one up cause tbh 18quid aint really alot like ![]() ________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
stan_306gti6
It isn't a lot, especially when you consider it's probably the cause of your poor fuel economy. Therefore, by spending the £18 it'll soon pay for itself in the fuel that you'll be saving. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
beez_neez_gt
Give them a clean with a toothbrush type tool with brake cleaner as mentioned. Then use some WD40 in the plugs to gain a better electrical connection as well as resisting water, the same goes for all the engine bay plugs.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
boost
would the thermostat stuck open affect performance ? and wheres the engine numbers on the 6 llump ? cause theres 2 isnt there the xu10j4r and the xu10j4rs ?________________________________________ 97 1.6 xs gti6 conversion scrapped99 black rallye ( low miles and immaculate new owner of a 2001 diablo red hdi mile muncher swapped99 red rallye turbo sold then died ![]() 00 moonstone 1.9d (slow) |
