displaying posts 176 to 200 of 289
Pages (12): first .. 7 [8] 9 .. last
Author Subject: the ZX 16v thread
Post #176
Sounds awesome mate! Thumbs up
Posted 13th Mar 2015 at 14:02
Post #177
Fuel pump arrived, fitted, test driven.
ERMAGHERD.
B A R K Big grin
Posted 13th Mar 2015 at 18:19
Post #178
Need more videos! Yes
Posted 13th Mar 2015 at 18:59
Post #179
I need some mounts for my GoPro or a willing assistant LOL
Posted 13th Mar 2015 at 19:28
Post #180
Done nothing to this since mapping but drive it and put fuel in, after replacing that fuel pump.
This clips into a small anti-surge cradle affair in the bottom of the tank, works very well, as long as you remember which way round it goes and to fit the pickup pipe/gauze filter!
The Walbro replacement units are a lot smaller than the Bosch original unit, so had to pack out the plastic/rubber bits a bit.
The supplied pickup filter wasn't any use as it was for an upright application, but the inlet is smaller than the Bosch pump so the original pickup tube didn't fit, luckily the handy bits of packaging they come with did the trick...
It has been a little reluctant to start first turn but fires fine after a bit of pedal prodding and cranking, once running its no problem, I'd also noticed that part throttle cruise, i.e 5th at 70 was sometimes not as smooth as it could be, a glance at the lambda and you could see it was trying to correct it quite a bit, I recalled Sandy was not a fan of the PTFE gaskets, though I had never had any issues on the standard inlet, I did have a pair of Elring gaskets so decided to try them
That's after a little clean up, I couldn't remember leaving it particularly grubby but it was, so might have been part of it maybe?
Also swapped the starter motor at DCC's suggestion, not sure the starter made much difference, as I still had to prod the throttle pedal a little to get it to catch, no popping this time though, but once it did it settled to a rather low idle.
and the warm idle was quite steady too.
Still seems a little rich to me on part throttle, can only think it would be due to the new fuel pump though at no point during mapping was the old one struggling to keep up with demand, I think I will get a spare set of injectors serviced, another set of picos for the front set and go and see Sandy again.
Posted 11th Apr 2015 at 11:40
Niall
Post #181
When i had the 6 mapped, that was on standard fuel pump which it turns out was failing and could not deliver enough fuel at times. Replaced it with a Walbro 255 and took it back for mapping and the whole lot had to be done again unfortunately.
Posted 11th Apr 2015 at 11:57
demondriverdan
Post #182
Sounds awesome! I'm hopefully going to be getting bodies fitted in the next few weeks along with an Omex 600. Looking on the web, I'm not sure if the 600 supports plugging a wideband straight in but if not I can work around it.
How does the backplate help?
Rallye Race Car
Posted 10th May 2015 at 20:23
Post #183
you mean the filter backplate? its something for the filter to clip to LOL
Posted 10th May 2015 at 20:37
pugheaven
Post #184
You fitted your satchshift yet???
Posted 10th May 2015 at 20:39
Post #185
nope, been too busy and I have nowhere to work on it, or a drill small enough to get anywhere near the bulkhead.
Posted 10th May 2015 at 20:41
Post #186
a brief update, not yet got the Satchshift fitted, I haven't got any drills small enough to get anywhere near the bulkhead to make the hole, also not having access to anywhere flat or a ramp makes things very difficult.
Got hold of some 205 Tarmac rear dampers, so much more chunky than the konis and the balance front to rear from a brief test drive is much improved.
As the ZX seems to sit quite low and these dampers simply will not compress by hand or lever, I had to get creative in their fitting!
I had also been experiencing some light vibration from the nearside rear brake under heavier braking, the discs had got particularly rusty when parked up last and seem to have glazed over and picked up some pad material in spots possibly, so Ebay to the rescue with some genuine rear discs, made sure the flanges were spotless before fitting of course.
20150523_173527 by WELSHPUG, on Flickr
and lastly something to have a fiddle with tomorrow possibly, a cobbled together used bits, thermostatic takeoff, pipes and an oil cooler, pipes should hopefully be long enough this time, the old Swaged set I still have weren't quite and these are a good few inches longer.
20150524_203740_LLS by WELSHPUG, on Flickr
Posted 24th May 2015 at 22:13
Rallyewoo2
Post #187
it has a bark, a hell of a bark for a standard engine with bodies and mild cams!!!
any vids of this bark mate!!!?
Kev
Posted 22nd Jun 2015 at 21:28
walker_texasranger
Post #188
That vid of it on the rollers is the tits... I want one!! Though not in a Citroen Razz
Hilux InvincibleX daily
306 No.13 Doh
Posted 22nd Jun 2015 at 21:45
Post #189
Amazing rear shocks !!!!
Transformed mine don't know which of the two on Kam website you got both Tarmac ones group n & other A one being twice the price both have black boots Thumbs up
Looking good Mei Thumbs up
I take it your going to Pugfest ?
Posted 22nd Jun 2015 at 21:56
Post #190
No I'll be in Belgium that weekend.
Posted 23rd Jun 2015 at 21:46
Post #191
Speedline sl434 by WELSHPUG, on Flickr
fancied a change of wheels..
Posted 5th Sep 2015 at 16:29
pug_306
Post #192
Had a set of those on a 205 years ago. Nice wheels. I think they suit the zx ;-)
1992 205 GTi6
205 Turbo 340bhp
Posted 16th Jul 2015 at 12:23
99rallye
Post #193
I don't normally like ZX but that looks the nuts
Posted 18th Jul 2015 at 17:59
Post #194
oh yeah, forgot to update, that Walbro unit failed too, which was a bit s**t, send it back but not heard anything, they say they've never had any fail yet, this just stopped randomly, in 3/4 of a tank of fuel.
nabbed a VDO unit from a phase2 xsara and bodged it in there, did the trick, not running lean anywhere though struggles to pick up fuel when its parked on the slope behind the house.
Posted 5th Sep 2015 at 16:31
RetroPug
Post #195
Is the plan for this to get painted eventually or is that not really a priority?
Posted 5th Sep 2015 at 18:50
Post #196
eventually yeah, or wrapped.
Posted 5th Sep 2015 at 19:39
RetroPug
Post #197
I see.
Really like the 3dr ZX. Haven't seen one for ages now, last ZX I saw was a ratty old diesel estate.
Posted 5th Sep 2015 at 20:50
Post #198
You better get it sorted if you plan on going to Pugfest / Precott next year ....lots of hills Crazy
Nice to have something a little diff from the norm Thumbs up
Posted 5th Sep 2015 at 21:34
Post #199
its fine going that way, its sideways it doesn't like LOL
Posted 5th Sep 2015 at 21:45
Post #200
Drifting's out of the question then LOL
Posted 5th Sep 2015 at 22:03
