Author Subject: Thread ruined on top mount bolts
pugbug
The 306 I purchased last year had a upper strut brace fitted, it appears as though the previous owner has damaged the treads either side (3 either side on top of the top mounts) I purchased some bolts from swampy and they don't lock in place. it doesn't seem likely I'll be able to tap a thread of the same size in there, any ideas?
Posted 3rd Nov 2012 at 20:04
mr swampy s16
**BAD SELLER**
Change the mounts??
Not that bad a job and Yuo can put new bearings in at the same time
Posted 3rd Nov 2012 at 20:10
JWP EFi
Turbo Legend!
i'd go with what swampy said, but you could drill and tap them out to M10, but getting the 3 bolts to line up with holes
in chassis could be fun
Posted 3rd Nov 2012 at 20:21
pugbug
Cheers for the replies guys. I'll have a look into to doing that. I'm not sure how everything bolts together, but is it safe to continue driving like this? It's not like anything is going to fall out?
Posted 3rd Nov 2012 at 20:30
JWP EFi
Turbo Legend!
personally i wouldnt drive it, get it sorted!
its fairly straight forward, you'll need to remove the strut, compress spring the take mount off
i really would just replace it rather than trying to drill/tap, plus their likely to be worn so replacing
mounts/bearings will help to tighten things up a bit
Posted 3rd Nov 2012 at 20:38
it'll be fine on 2 bolts, the zx only had two.
you could just send a 10mm tap through it after drilling to 8.5mm.
Or use a longer M8 bolt and a nut underneath.
Posted 3rd Nov 2012 at 20:50
smithers
Did someone not do a trackday with no bolts in?
1997 Black GTi6
smithers205 at hotmail.com
Posted 3rd Nov 2012 at 21:00
rich306
It's a right b**ch to get the nut on underneath though!!
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 3rd Nov 2012 at 21:58
darzmat
a couple o mine are nuts and bolts as i knackered my threads by over tightening.
never ad a problem taking them on or off
Posted 3rd Nov 2012 at 22:28
