displaying posts 101 to 125 of 142
Pages (6): first .. 4 [5] 6
Author Subject: 306 BTCC
blandy
Post #101
That looks awesome any specs? Or are they closely gaurded lol
Posted 29th Mar 2013 at 20:24
scotzman
Post #102
What sort of HP should it make?
Posted 29th Mar 2013 at 20:36
Carl Chambers
Post #103
full spec on our website
www.pugsport-racing.co.uk
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
Carl Chambers
Post #104
originally it was around 275bhp so hoping it will be close to that
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 29th Mar 2013 at 20:37
vts_tibi
Post #105
WOW! Congrats for the airbox you did! Looks awsome! What is the filter part number? I guess it's K&N brand.
What are those two things on top which keep it in place? Can't really make out of the pic.
VTS
best 60' : 2.272
Team Trackday™
Posted 29th Mar 2013 at 21:01
Carl Chambers
Post #106
thanksSmile took ages to make and couldnt get the airfilter as far forward as wanted but pleased with how its turned out.
the airfilter is k and n and is for a Renault Safrane 3.0 v6 part number 33-2710
the 2 parts on the top and sides are just bent metal brackets.
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 29th Mar 2013 at 21:08
jeffers Forum Admin
Post #107
Carl, I see the spec on the website but would you elaborate on the engine spec for interest or u keepin it under wraps? I understand by the way if u want to keep it quiet! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 30th Mar 2013 at 00:05
Post #108
Just a rebuild isnt it?
Posted 30th Mar 2013 at 03:49
Carl Chambers
Post #109
yes nothing else done. just the jenvys and omex added
I dont know a great deal but its got Longmans cams, lots of head work, slightly bigger valves, Omega pistons, Peugeot sport rods and special 40mm bearing crank. All pretty much as it was when it raced, apart from it should have had a 45mm crank, which would have made it easier to get some shell for it!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 30th Mar 2013 at 08:06
gtibetty
Post #110
Saw btcc in the flesh yesterday looks fantastic and another A1 build by you carl, both cars look great together, rekon i should be your team mate lol, looking foward to the first race at snett.
Posted 31st Mar 2013 at 19:37
blandy
Post #111
But of a odd one but have you got any pics of your rad set up and header tank plumbing as see it doesn't use a normal 306 rad
Posted 7th Apr 2013 at 08:26
JWP EFi
Turbo Legend!
Post #112
whats its rev limit btw?
Posted 7th Apr 2013 at 20:52
Post #113
Peak power plus a few hundred LOL
Posted 7th Apr 2013 at 21:49
7057sam
Post #114
How did your test day go?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 7th Apr 2013 at 21:57
JWP EFi
Turbo Legend!
Post #115
that low?!
Posted 7th Apr 2013 at 21:58
Post #116
Peak power is probably a bit higher up the rev range than standard Wink
Posted 8th Apr 2013 at 10:35
Carl Chambers
Post #117
Peak power is at 8k rpm!
Sam it survived the test day just, starter has died and rad is now leaking so got to get both sorted by next weekend, starter is easy rad wont be quite so!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 8th Apr 2013 at 20:53
Post #118
Is it the core or one of the welded end tanks leaking?
Posted 8th Apr 2013 at 20:59
Carl Chambers
Post #119
its cracked where the core meets the end tanks
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 8th Apr 2013 at 21:11
Post #120
Bung it in the post, I'll weld it up for you.
If you want that is.
Posted 9th Apr 2013 at 00:09
Carl Chambers
Post #121
thanks for the offer but due to needing it back Friday I have had to have a local company re-core it, not cheap but the quickest and easiest way to ensure its done in time, no post to worry about.
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 9th Apr 2013 at 08:33
Post #122
Seems a bit extreme when its just a cracked weld, but at least it will be %100.
Posted 9th Apr 2013 at 08:39
demondriverdan
Post #123
Bugger, I'm in Newcastle when you're at Brands! It'll have to be Snett in October before I can see the car on track
Rallye Race Car
Posted 9th Apr 2013 at 23:10
Carl Chambers
Post #124
well after all the effort the first race at Snetterton was a disaster!
had a misfire most of qualifying, then it all came back for almost 1 lap and died!
TDC sensor end was knocked off! and coil pack was faulty! replaced both but feared clutch was breaking up but no time before race to do anything so had to risk it!
Race went superb for 3 laps! went from 11th to 5th in that time and was catching the 4 in front but coming out of Murreys there was a bang followed by lots of clutch slip. Coming into Russels it all died again with TDC sensor getting knocked off again!
one unhappy driver
but it went so well for them 3 laps which is what saving it from being for sale on ebay now!
plus found that I was able to drive it at the speed in order to be competitive so just hoping to sort it out for Brans in 3 weeks!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 16th Apr 2013 at 21:02
24seven
Post #125
We had the same problem on the uni's Formula Renault at Silverstone a couple of years ago. A part of the clutch flew off and took out the crank sensor. Data showed that the driver had buzzed the engine briefly when it happened and everyone assumed the worst and that there had been piston-valve contact so the engine was stripped down, only to be absolutely fine! 10 minutes of head scratching later and the shafted crank sensor was spotted. LOL
Posted 17th Apr 2013 at 01:30
