Author Subject: Pair of home brew bilstein coilovers £250 with springs and
talbotsteve
Built using impreza inserts in hybrid subaru peugeot bodies and 2.25 coilover conversion. Springs included will be the blue ones brand new 12" 350lb. Brand new alloy top mounts. £250 collected from Cumbria or arrange your own courier.
Cheers Steve.
MMMM you won't like this but I just love Citroens!!!!!!!
Posted 12th Nov 2012 at 10:36
pugheaven
What adjustments do these have other than ride height, rebound, dampening etc
Posted 12th Nov 2012 at 10:53
talbotsteve
No just ride height and the strut tops are castor camber adjustable. the bilsteins are canisters and are rebuildable.....
Posted 12th Nov 2012 at 11:02
what's the damping rate of the inserts?
Posted 12th Nov 2012 at 12:35
talbotsteve
Unsure just those issued by Prodrive. Unlike the inverted bilsteins on a group 4 escort which have the damper rating stamped in the top these are a canister insert similar to the later peugeot sport suspension and they have no markings, the damper is quite firm and with the 350 rated spring would make an excellent fast road track setup.
I have tried them against some 300/120 gpn cossy inserts I have and the feel and rebound is much the same, and they came off an irish tarmac set up escort cosworth, mainly used for single venue stuff so firm but not knock your teeth out type stuff....
Steve.
Posted 12th Nov 2012 at 14:18
pugheaven
what is the maximum that it can lower a 306 by if you measured from the sidesill, only reason i ask is as i have a dimma im wondering if that setup would beable to give me the drop i require, i know that i could change the spring length but i still think i will need short inserts??
Posted 12th Nov 2012 at 16:40
You'll need raised inner arches if you want to go low on a Dimma.
Posted 12th Nov 2012 at 16:51
pugheaven
Iv seen how nur is doing his but i dont intend to go that low, a nice 2-2.5" gap would be nice, still have the problem of the roll centre kit hitting the rotors so it would be good to know if the brake setup he is selling will give me the extra clearance due to the offset and these coilovers give me the required drop i require.
Posted 12th Nov 2012 at 16:58
talbotsteve
The ride height is dictated but the spring height, this kit with my wide arch kit on the xsara was just about right, due to big arch clearances I needed adjustability as I was running out of damper length on standard struts and lowered springs.
Posted 12th Nov 2012 at 19:50
talbotsteve
Still here.
Posted 13th Nov 2012 at 20:56
talbotsteve
Bump. Back up forsale.
Posted 23rd May 2013 at 16:00
talbotsteve
Bump.
Posted 10th Jul 2013 at 01:13
