Part im looking at is 5031 60 Mounting Ass (number 10 on diagram) is this right or will it be a case of I should only require the actual bearing?
darkstar753 has attached the following image:
Darkstar
| Author | Subject: Top Mount Part Number |
darkstar753
Regular Location: Enfield Registered: 12 May 2011 Posts: 241 Status: Offline |
Looking to refresh my suspension over xmas and wanted to check I had the right part number for a top mount refreshPart im looking at is 5031 60 Mounting Ass (number 10 on diagram) is this right or will it be a case of I should only require the actual bearing? darkstar753 has attached the following image: ________________________________________ Darkstar |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Number 10 indeed, I bought one not so long ago.52 each iirc ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
darkstar753
Yea £51.46 according to servicebox________________________________________ Darkstar |
jord294
item 2 isn't included in the kit, and price each is around £20________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
darkstar753
Is that part required, as I cant imagine it wearing out - could be very wrong of course.________________________________________ Darkstar |
really depends on the condition, if you only need the bearings good ones can be had in the aftermarket for about £8.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
c_j_m
Seasoned Pro Location: Andover Registered: 23 Sep 2007 Posts: 1,917 Status: Offline |
Complete skf kits are around £55 from ecp for the pair and thats before any discount and they have 30 off atm with the code midmonth30 which makes them under £40!http://www.eurocarparts.com/ecp/c/Peugeot_306_2.0_2001/p/car-parts/suspension-and-steering/suspension/suspension-mounting/?669730040&1&b057217cc385ade26cd4a62c7d78eeebe53d8ddf&000872 |
darkstar753
Wasnt 100% sure if that price on ECP was for a pair or just for one side :s ________________________________________ Darkstar |
"qty per axle:1"pic shows a pair, I'd go with it being a car kit rather than single side kit. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
darkstar753
true, well we'll see probably worth a shot may have to see what the SKF guy who appears at work occasionally can lay his hands upon________________________________________ Darkstar |
Those #2 rest cups, are they generic between 205's and 306's?________________________________________ ![]() |
they look like they would be, but easy enough to check, just cross reference the part number, given its the same bearing, and quite a few 205 springs are also used on 306's and partners, I;d say they would fit, but can;t remember if the part numbers are the same ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
To be fair I could go and dig out one of each shock and pull the top off and check myself by comparing, but thought I'd ask incase it was common knowledge to save the effort ![]() ________________________________________ ![]() |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
darkstar753 wrote: Is that part required, as I cant imagine it wearing out - could be very wrong of course. Might be quite rusty, but it is pretty thick steel. Could be de-rusted and painted. Check the condition of bump stops/dust boots as they need to be in good nick to stop crud getting onto the rod. Mine were perished. ________________________________________ Cherry Rallye SOLD |
c_j_m wrote: Complete skf kits are around £55 from ecp for the pair and thats before any discount and they have 30 off atm with the code midmonth30 which makes them under £40! http://www.eurocarparts.com/ecp/c/Peugeot_306_2.0_2001/p/car-parts/suspension-and-steering/suspension/suspension-mounting/?669730040&1&b057217cc385ade26cd4a62c7d78eeebe53d8ddf&000872 Skf are a rubbish fit Get original or don't bother |
darkstar753
That seems surprising from SKF, they're oem for pretty much every rail wagon I've ever come across, thought u would be fairly safe with them. ________________________________________ Darkstar |
Get the peugeot ones dude. Buy cheap buy twixe with this s**t and its a pita to change once its on________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
