Author Subject: Lighten Flywheel & Valve Springs
speedo306
Hey mates,
Any idea when fitting a lighten flywheel and crank pulley do you have to do any work on the crankshaft.
I just want an idea of the steps to take when fitting these parts so that I do the right thing.
Can piper double valve springs be fitted to my gti6 head? What will be difference as compared to the standard springs.
Thanks.
RJ
Posted 24th Nov 2012 at 03:15
I have a lightened flywheel and lightened crank pulley and both are fine on a standard crank. As for valve springs, you don't need to upgrade them. I'm running over 450bhp on standard valve springs. Yes
Posted 24th Nov 2012 at 07:16
speedo306
thanks mate
RJ
Posted 24th Nov 2012 at 12:05
Depends what you want to rev to, pistons and rods are the weak link before valve springs though.
Posted 24th Nov 2012 at 12:13
What he said.
I think the standard ones are doubles anywho
The only thing you would even really NEED to consider would be the hydraulic lifters
But only if you are aiming for a high rev limit say above 8k in a track day/ race engine.
All the High boost lot dont bother as its only a consideration if you are hitting that all the time.
Posted 24th Nov 2012 at 12:14
Yeah, if you're using over 8k on a regular basis then you should move to solid lifters really. Yes
The standard valve springs are doubles, yes.
Posted 24th Nov 2012 at 12:37
miles
Springs are suited to cam specs and not the other way around
www.pugracing.com
Posted 24th Nov 2012 at 17:46
