Author Subject: Newbie help! Facia lights won't work !
Markj
Hi all - after reading a thread on replacement of heater control bulbs it seems none of the facia light will now work.
The heater lights, the dashboard lights and also the 'light still on ' warning alarm will all not work.
The actual act lights work but I am driving in the dark at present!
Any ideas anyone?
Any help is much appreciated!
Btw I have a 306 hdi 2001
Thanks!
Mj
Posted 24th Nov 2012 at 15:05
check the fuses and the dimmer switch is plugged in.
Posted 24th Nov 2012 at 15:11
Markj
Thanks! Will give this a go and let you know.
Mj
Posted 24th Nov 2012 at 15:59
tvrfan007
I'm guessing your dash dimmer hasn't been touched as Mei suggests, thus I would wager Fuse 11 will be blown.
I've had both afflications on my Rallye, both had the same net effect only the fuse killed the odometer too.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 24th Nov 2012 at 16:29
Markj
Thanks for the advice - have looked through the Haynes for some guidance but came away more confused!
The manual states it is a 28 fuse holding box but I count more. Will give the fuses a check over and replace. Are you counting number 11 from the top left along?
Mj
Posted 24th Nov 2012 at 16:42
tvrfan007
Your Haynes is referring to the phase 2 fuse box. Look on here in the faq section for the phase 3 fusebox map. It will show your fuse 11.
I'm Si btw Tee hee
Posted 24th Nov 2012 at 19:01
tvrfan007
Think the numbers are visible in the plastic. Anyway, http://www.306gti6.com/forum/showthread.php?id=64509 will show you, one in from bottom right in the bottom row.
I'm Si btw Tee hee
Posted 24th Nov 2012 at 19:05
Markj
Thanks Si.
On my way to sort it now after a heavy night shift!
Will keep you posted - thanks again for the heads up
Mj
Posted 25th Nov 2012 at 12:50
