Author Subject: Rebuilt beam
JWP EFi
Turbo Legend!
I will be building 2 GTi6 beams up over next week, new genuine bearings and seals
Pm for details
Posted 30th Nov 2012 at 22:01
need to state a price mate,forum rules Thumbs up
Posted 30th Nov 2012 at 22:26
JWP EFi
Turbo Legend!
£220. this is to supply a beam with new bearings, seals and fixings where required
Brake lines, discs, pads, calipers, abs sensors, mounts, dampers will be extra
Posted 30th Nov 2012 at 22:45
scotzman
Good price!
Posted 30th Nov 2012 at 22:48
JWP EFi
Turbo Legend!
also this an exchange basis
Posted 30th Nov 2012 at 22:51
6waysforward
Ahhh why so far away Sad
Posted 30th Nov 2012 at 23:18
JWP EFi
Turbo Legend!
can be delivered, would need to check price
Posted 30th Nov 2012 at 23:25
eddy_gti6
Is that all paonted up too so they look nice? Laugh my ass off
Posted 30th Nov 2012 at 23:58
jord294
No new trailing arm shafts then ?
Posted 1st Dec 2012 at 01:00
JWP EFi
Turbo Legend!
i have a selection of used pins that are in perfect condition, no wear whatsover.
if the customer requests new pins then the above price will obviously rise some what
All used pins are checked in a lathe to check they are true
Eddy - the tube and trailing arms can be painted black and the torsion bars red or if you want a
pimped out beam in all the original colours then i can do that, at an extra cost
Posted 1st Dec 2012 at 10:32
pics of good shafts plz
Posted 1st Dec 2012 at 10:49
JWP EFi
Turbo Legend!
bear with me....
Posted 1st Dec 2012 at 10:51
6waysforward
Delivery cost please sir.
Delivery postcode ss0 9pw.
Posted 1st Dec 2012 at 11:00
JWP EFi
Turbo Legend!
approx £80, will get exact price on monday
Posted 1st Dec 2012 at 11:15
JWP EFi
Turbo Legend!
As you requested...
Posted 1st Dec 2012 at 19:53
I would not use those.
Posted 1st Dec 2012 at 19:57
JWP EFi
Turbo Legend!
why not? they are fine, no wear ridges whatsover. the markings in the pic suggests they are worn
but can assure you they aren't
Posted 1st Dec 2012 at 20:00
the markings is where the rollers have worn through the machined surface, wont take long and you'll have pitting.
Posted 1st Dec 2012 at 20:07
JWP EFi
Turbo Legend!
nope, theres no pitting. the diamaters are consistant, 47mm on outboard side and 42mm on other
i have access to a very experienced engineer/turner, he inspects them for me. I wouldnt sell these
to someone if i thought they were worn
Posted 1st Dec 2012 at 20:10
martin
I can vouch for these babies .. had seb build me a rear beam with uprated to torsion bar and anti roll bar arms. I also got some eibachs off miles and got the lot done and can't fault the work. Top fella.
Posted 2nd Dec 2012 at 15:51
