Author Subject: Oil filter relocation kit
pugheaven
Has any one used one of these before?
I'm thinking about getting one for the Dimma, can any one see a down side to these set ups?
I would re-locate the filter to the battery Bay Area as that will be in the car, at the moment iv got the water/oil heater take off then the oil cooler take off and then a slim filter, iv got another take off plate for my oil temp and pressure gauge, this will leave bugger all room if any between the filter and fans.
With the relocation kit it comes with 2 sensor take offs on the new relocated filter housing so I wouldn't need my take off plate, however I assume I would still have the heat exchanger then oil cooler take off and then the relocation kit take off plate?
In short are these kits any good?
Posted 1st Dec 2012 at 22:13
They work, many pugs had them as standard back in the day due to space Constraints, quite a few used the heat exchangee bolted to the front of the gearbox so the coolant pipes off the top hose were quote a lot shorter.
Posted 1st Dec 2012 at 22:31
simonjames
not seen these, may be handy for my rallye to be able run a cooler as my pipes run close to the filter
MY EBAY ITEMS
07943066306
Posted 1st Dec 2012 at 22:33
pugheaven
Iv looked at lots of kits on flea bay but I only really want the take off plate and new filter housing as the braided lines they come with look of crap quality, only problem With this is most complete kits/ plate kits have the ports facing forward on the take off plate so would still stick out quite a bit once you have the male to male adapters and right angle unions!
One kit has the ports at the side of the take off plate (like a oil cooler take off plate) which would give me a lot more room!
Servicing would be easier and less messy too Smile
Posted 1st Dec 2012 at 22:47
Shift the heat exchanger as well Smile
Posted 1st Dec 2012 at 22:50
pugheaven
Been thinking that, still best to keep the cooler take off plate in its original location isn't it?
Only down side is more weight in braided lines and unions, more ££ for more oil, get shares in royal purple me thinks!
Posted 1st Dec 2012 at 23:02
Only need a remote oil filter when using dry sump systems Yes
I looked into ages ago dude Yes
Posted 1st Dec 2012 at 23:10
Because Im a twat.
What is the main advantage of dry sumps?
I assume its partly to do with oil surge?
Posted 1st Dec 2012 at 23:12
eliotrw wrote:
Because Im a twat.
You take an uncontrolled oil environment and change it to controlled.
Basically you feed just enough oil into the engine when it needs it so reduces drag on the crank.
And yes it's supposed to reduce oil surging Yes
Posted 1st Dec 2012 at 23:24
pugheaven
Oil Filter Relocation Kit
Allows Installation of Larger Oil Filter
Increases Engine Oil Capacity Available , Enhances Oil Lubrication and Protection of Engines
Oil Filter Relocation for Easier Access, a Must for Hard-To-Reach Oil Filters
No need for a dry sump set up at all!
Posted 1st Dec 2012 at 23:29
midlife
x 2
I used a remote filter on my Rover V8 powered Sunbeam due to space constraints, I mounted it where I could fit a much larger than std filter & it was easy to get to.
Iirc I used a normal oil cooler take off with a cast blanking plate to feed the remote filter.
Cool
Team 330™Cool
Team "no front end or engine"
Posted 1st Dec 2012 at 23:49
pugheaven
So you used 2 take off plates? One in the block with a blanking cap for the end and the other with a filter and blanking plate??
You can buy the 2 plates for £40 then just lines and unions plus they have 2 take offs for gauges = result
Posted 1st Dec 2012 at 23:53
eliotrw wrote:
Because Im a twat.
1.) Less drag from the crank in the oil as the dry sump system scavenges the oil straight out of the sump.
2.) Can release more power by generating a vacuum in the crankcase (reduces pumping losses and helps ring seal)
3.) No oil surge issues if correctly designed.
4.) You can mount the engine much lower due to the sump being far thinner (as the oil is stored in a deaireation tank elsewhere), improving the center of gravity of the drivetrain and usually allowing the engine to be packaged closer to the centre of the chassis.
Posted 1st Dec 2012 at 23:55
pete_rallye
I had some small alloy blocks welded into my cooler hose take off, which I then tapped and drilled to suit the temp sensor. You would also be better off remotely mounting your pressure sensor as they don't like the constant vibration associated with been bolted to the engine. Other way you could do it is to buy an adapter which could go on the hose which you could mount pressure and temp sensors into. My pressure sensor is mounted on the wing and connected, via a bit of -3 hose, to an adapter that goes into where the standard pressure switch goes, just above the filter.
Lap of the 'ring
Posted 2nd Dec 2012 at 00:07
midlife
No I used a normal oil cooler take off plate with a blanking plate to feed the remote filter.
Just like this one...
Cool
Team 330™Cool
Posted 2nd Dec 2012 at 00:40
midlife
You could get one of these bad boys...
Cool
Team 330™Cool
Posted 2nd Dec 2012 at 01:13
^^^ Damn you Midlife! Magpie mode, Activated!!!
Posted 7th Dec 2012 at 14:33
phillipm wrote:
eliotrw wrote:
Because Im a twat.
So basically
They are awesome
Posted 7th Dec 2012 at 14:38
russbez
they do look rather shiny!!
My Rallye project thread
Posted 7th Dec 2012 at 14:52
mabgti
NV motors
Its a good idea , but ive seen a few horror stories with cheap lines!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 9th Dec 2012 at 20:49
midlife
The same could be said with any oil cooler installation though...
Cool
Team 330™Cool
Posted 9th Dec 2012 at 21:26
midlife
You're welcomeLaugh my ass off
Cool
Team 330™Cool
Posted 9th Dec 2012 at 21:27
eliotrw wrote:
So basically
They are awesome
Pretty much.
My pump ships out from Pace tommorow Whistle
Posted 9th Dec 2012 at 21:41
devere
phillipm wrote:
eliotrw wrote:
So basically
They are awesome
Pretty much.
I hope there customer service was better for you than me, it took me a 100 mile round trip, and then another 6 months just to get a pump rebuild kit and a couple of belts!
Cant remember his name now, but there sales guy was fcuking useless. Never called back, never sorted things out.
Despite that there parts are good!
Posted 9th Dec 2012 at 22:00
Don't ring sales, they never want to sell anything, head office ftw. Big grin
Posted 9th Dec 2012 at 22:06
