Author Subject: gti 6 wont start
mike rallye
hi guys, am after some advice. went to start the car this morning and it started and cut out. have tried starting it since then and it just wont fire up am going to check the following
1)timing belt
2)spark plugs
3)fitted new speed sensor
what else could I try and look for.
thanks in advance
Posted 3rd Dec 2012 at 08:28
Firstly check the timing belt is ok.
If this checks out then you need to determine whether or not you have a spark. To do this, take a coil pack and spark plug out, put the plug back in the coil and then place the threaded part of the plug on the cam cover to give it an Earth and hold the coil pack. Get an assistant to crank the engine. You should see the spark plug sparking, if not you have no spark and I would imagine the crank sensor will be the culprit. Yes
If you have a spark then you need to look at the fuel system. Does the fuel pump prime when you switch on the ignition?
Posted 3rd Dec 2012 at 08:35
As above, plugs could tell you whats wrong.if they are wet you might be lucky and it's just flooded.
If there is no spark and no fuel good chance it's the crank sensor, as that's what let's the ecu know the engine is turning overThumbs up
Otherwise have you changed/fitted anything new to the engine recently?
Posted 3rd Dec 2012 at 08:53
mike rallye
cheers guys will give them a try. I can hear the fuel pump kick in when I turn the ignition on.
but will inspect the timing belt first, followed by the plugs.
no new parts have been fitted lately.
what I have noticed those, is when the ignition is on the engine light stays on. normally they go out don't they with just the ignition on?
Posted 3rd Dec 2012 at 09:04
fordygti
I had this problem of car not starting after changing the loom and fitting a sc kit. It turned.out somewhere.it had dropped.an.earthe.so.the plugs wernt sparking and.the injectors aren't.putting fuel.into the rail. Another idea if that helps.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 3rd Dec 2012 at 09:43
peetypug
My rallye had this not long ago and it turned out the immobiliser was not sending a signal to the ecu
Unlocked ecu sorted it, so if the other checks fail may be worth checking that
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 3rd Dec 2012 at 09:51
mike rallye
how would I check to see if a immobiliser fault or a ecu?
Posted 3rd Dec 2012 at 09:56
See if you have a spark. If you don't and a new crank sensor doesn't sort it then it's likely it is an immobiliser problem. Yes
Posted 3rd Dec 2012 at 13:13
mike rallye
Result ,it is alive again
after checking the timing belt and finding this was fine, I then took a guess on buying a crank sensor. once I managed to fit the new one (fiddly to do) if fired into life. so at the moment it is going well.
thanks for the advice and help guys Thumbs up
Posted 3rd Dec 2012 at 18:27
No problem, glad it's all sorted mate! Thumbs up
Posted 3rd Dec 2012 at 18:51
swiftyboi006
Stans the man once again
Black p3 Love
Posted 3rd Dec 2012 at 18:56
swiftyboi006
Stan'll fix it for ya
Black p3 Love
Posted 3rd Dec 2012 at 19:01
I'm not sure I want that jingle...LOL
Posted 3rd Dec 2012 at 19:39
swiftyboi006
Laugh my ass off Thumbs up
Black p3 Love
Posted 3rd Dec 2012 at 19:59
mike rallye
LOL
Posted 3rd Dec 2012 at 21:19
